Tugboat
Posted: Fri Apr 04, 2003 11:03 am
by Barthax
This game should be archived. Input only functions for the first stage. After that there is no control.
Posted: Fri Apr 04, 2003 12:57 pm
by LN2
I'll try that one myself to see if I see the same thing..if so then I would of course agree it should be archived.
Some games are just really picky on playback. I assume you tried playback at exactly same settings you used to play it. If not sure, then that might be the problem.
For example some games lose sync on playback if you use different frameskip or even if you have the speed throttle off or change audio settings.
Posted: Fri Apr 04, 2003 2:50 pm
by Barthax
LOL. I'm talking about playing the game! I've tried it on XMAME 0.66 and AlphaMAME 0.66 - the second stage will not take input *while playing*.
Posted: Fri Apr 04, 2003 3:53 pm
by LN2
oh..not even recording...but input from any device started at stage 2 stops ehh?
I'll try it in macmame 66 to see if same thing....if so then obviously the game isn't functioning properly so should be archived.
Posted: Fri Apr 04, 2003 6:35 pm
by Haze
its a known issue so i'd hope it happens in all mame versions
Posted: Fri Apr 04, 2003 10:40 pm
by LN2
Yep...does same thing in macmame66.
This game is actually marked as "not working" within macmame.
It definitely should be archived.
Posted: Wed Apr 09, 2003 1:22 pm
by ***PL***
Tugboat has been archived -- controls stop working in stage 2
