nycaptor (ansollena)
Posted: Fri Dec 13, 2002 6:53 pm
by DRN
http://marp.retrogames.com/inp/ans_nyca ... _win62.zip
Will not playback, tilts straight away with or without sound and regardless of what frameskip setting you use.
Posted: Fri Dec 13, 2002 11:28 pm
same here, looks like this is a sound off only game.
Posted: Sat Dec 14, 2002 4:27 am
by Frankie
I can't get it to playback either, tilt right away. Zeroed.
Posted: Sat Dec 14, 2002 9:54 am
by ansollena
I don't know what's happened.... i'll check.... sorry...
If this don't work, i'll try to record another one. :D
Posted: Sat Dec 14, 2002 10:38 am
by ansollena
Ok... tilt also for me. :cry:
I don't know why! I prefer to play this game with mouse... but if i go in "controllers", i can't enable mouse input! So, i have enabled lightgun input and i've seen that in this way i can play with mouse! ..... But, in this way, when i try to play a match, tilt appears!!!!!! Why??? :?
Is not possible playing with mouse? I'll proceed with furthers tests.....
Sorry for all...
What a shame for me...
Posted: Sat Dec 14, 2002 11:32 am
by Buttermaker
Always test your inps before uploading.
Use the command line version and start the game with -mouse.
Edit: You need to enable mouse support in the default options in MAME32.
Posted: Sat Dec 14, 2002 1:02 pm
by DRN
Also make sure you record with no auto frameskip otherwise it just wont work. I'm pretty sure you'll get a more reliable recording if you record without sound as well. Good luck.
Posted: Sun Dec 15, 2002 10:14 am
by ansollena
Ok! From 1083440 (zeroed) to 5625310 !!!!!!! :P
I think now playback is possible... you now can try!
I used noframeskip and mouse. I think previous trouble wasn't mouse, but frameskip.
Yeah! :wink:
