MARPFront 0.2.2 beta
http://mahlemiut.marpirc.net/marpfront022.zip
Thought this new feature was worth upping the version and making a new topic. :)
Anyway, the new feature is auto download and playback. You just get the score details from the high score list for the game of your choice (double click the score as per usual), and click the 'Download and playback' button, and of it goes. It will search for the version listed in your version list, but if it's not found, it will use which ever is the currently selected version.
Now, this also means that the format of versions.ini is a bit different, with an extra field for the version name (should match what MARP uses, ie: 'mame61', 'mame58'... It is this field (it should be the third of the now four field for each version) that is used for the version search. See the included example ini if you're still not sure how it should look.
Have fun. :)
EDIT: Updated version, fixes problem with uppercase INP filenames.
kfx
Post by kfx »
What does the 4 line in the ini file do?
storm
OS : winXP
cpu : P4 3gzh
First line is a descriptive name of the MAME version. This is what will appear in the dropdown listbox.
Second line is the path to the MAME executable, including its filename. This is what MARPFront will call when you want to play/record/playback a recording.
Third line is the short version name used to search after downloading a recording. This should match what MARP uses. (eg: 'mame55', 'mame60'...)
Fourth line is the port of MAME that it is. So far only "Win32" is supported, for the Win32 CLI version. Maybe one day, I'll add DOS support.
0.2.3 released
http://mahlemiut.marpirc.net/marpfront023.zip
Quick bugfix release. Thank Francois and his odd folder structure for his zips for this one.
- Added a little download progress indicator.
- Fixed a bug that caused Marpfront to crash if it encoutered an inp in a folder within a zip file.
