Page 1 of 2
Toki poll - Second try.
Posted: Fri Sep 20, 2002 5:40 pm
by Frankie
We never found out what to do about Toki. So on request from QRS I start a second poll, leaving out the option that got the least votes in the first poll:
viewtopic.php?t=9637&start=0&postdays=0 ... highlight=
Happy voting MARPERS.
Posted: Mon Sep 23, 2002 3:54 am
by MDenham
WTF WHO'S IN FAVOR OF LEECHING
Posted: Sat Sep 28, 2002 7:17 am
by Frankie
Voting is over, and it was decided that this game, and all its clones must be played on 'hardest' to prevent leeching.
I've made Special Rules for all 5 Toki games, which also includes information on how to check if the recording was recorded on 'hardest'.
QRS: Is my Special Rules description okay?
TOKI PLAYERS: I'll wait a week or so, before I go through the games to check if all of them where recorded on default (probably). If you have a Toki recording that you know was recorded on a difficulty below 'hardest', please go and delete it yourself, and make life easier for me, and the other editors
RE
Posted: Sat Sep 28, 2002 8:20 am
by QRS
Sounds correct to me Frankie. You can also add to the special rules that on the first boss it requires 2-3 shots/ape on the hardest settings compared to 1 on default settings.
ps I will delete my recordings as fast as I can or try to make better ones with hardest settings.
Regards
RE
Posted: Sat Sep 28, 2002 8:27 am
by QRS
Stupid me.... You can see what difficulty the game has in the beginning when you start the game.. A big screen wich tells all setting including what difficulty the game has for the moment. Make sure that it says "Very Hard" there wich means that it is set on "Hardest" in the dipswitches
And I find out that now after playing that game hundreds of times.. talk about retards
Re: RE
Posted: Sat Sep 28, 2002 9:01 am
by Frankie
QRS wrote:Stupid me.... You can see what difficulty the game has in the beginning when you start the game.. A big screen wich tells all setting including what difficulty the game has for the moment. Make sure that it says "Very Hard" there wich means that it is set on "Hardest" in the dipswitches
I didn't see that either, that makes two retards
I'll change the Special Rules, telling people to watch for this instead.
Posted: Sat Oct 12, 2002 7:48 am
by Frankie
I've zeroed all recordings on Toki and all its clones that was played on a difficulty setting below 'hardest'. This was indeed all of them
So, for all you Toki players, start submitting your new recordings on 'hardest'.
Posted: Thu Feb 27, 2003 2:05 pm
by Blost
Well, as changing difficulty clearly didn't eradicate the leeching bit(s), maybe we can reverse it back to medium & find another way?
Blost (who plays Toki on normal settings).
Posted: Thu Feb 27, 2003 6:37 pm
by LN2
if people are still able to finish the game and leech in spots at hardest setting then why lower it again to medium?
Is it because perhaps you can't hack hardest? hehe
No reason to lower the difficulty IMHO given so many can still complete the game at the hardest setting....regardless of the leeching issues.
There was a separate vote newer than this one addressing that also....and I think it was decided the leeching is allowed as long as you complete the game. Check the special rules to see if that is the case.
Posted: Thu Feb 27, 2003 6:51 pm
by DaviL
I don't known this game, but if there are so much good players that finish the game without problem why not 1 life only and normal difficult ?
Ok still can leech but only the best will be N°1.
Posted: Fri Feb 28, 2003 5:50 am
by Francois Daniel
DaviL wrote:I don't known this game, but if there are so much good players that finish the game without problem why not 1 life only and normal difficult ?
I agree because I don't know where is the problem to leech at this game. The leeching is on the last stage on the plant boss. Change the difficulty doesn't change anything. The one who reach the plant can leech forever. That doesn't prevent leeching.
The best is the one who make the best amount of points when the end of the game is reach.
For most game, the goal is to reach the end of the game. Why nobody here doesn't ever suggest to accept any leech (for any game) only if the ending is reach as a general rule for games who have ending ?
Posted: Fri Feb 28, 2003 11:23 am
by Blost
LN2 wrote:Check the special rules to see if that is the case.
Well all it says is : "It was decided in a poll on the Board that we must play this game on difficulty 'Hardest' to make it impossible/harder to leech."
As it's clearly not the case, i don't see why this rule exists anymore...
Posted: Sat Mar 01, 2003 1:10 am
by LN2
Well, my guess is it still makes leeching harder than it was at medium difficulty. Yes, it's still present...but likely would be even more extreme at medium difficult.
At least that's how I read that decision.
Posted: Sat Mar 01, 2003 7:05 am
by destructor
Toki is very simple game. On stage with plant this isn't leeching but maximizing score. There aren't extra lives after points. Finished Toki with 1 live is no problem.
Sory for my English.
Posted: Sun Mar 02, 2003 4:40 am
by Francois Daniel
destructor wrote:Toki is very simple game. On stage with plant this isn't leeching but maximizing score. There aren't extra lives after points. Finished Toki with 1 live is no problem.
Soty for my English.
Yes, I agree. Furthermore, they're a time limitation in the game. So, I don't understand why its a problem to leech/maximize.
Francois
