You broke MARP Sampras...
gameboy9
Post by gameboy9 »
Scoring 2,196,317,710 in mystston is greater than the scores allowed on MARP - but you take over possession of the top score ever on MARP. Only problem is... you were penalized 50 million thanks to MARP limitations... :)
http://gameboy9.marpirc.net
sikraiken
Post by sikraiken »
Cool! ^_^ As I believe Barry stated before, this will occur also when Giga Wing is XORed. :)
BTW: Someone should atleast edit the description to put in the actual score.
Description edited. Now we just need Zwaxy to fix MARP to use 64-bit integers now. It should be real easy to break this score in Giga Wing too.
291兆0919億1996万6740 is the current Gamest record. :)
EDIT: This board don't like Japanese encoding... 291,091,919,966,740 is the Giga Wing record.
Novice
The greatest info supplyer
Post by Novice »
DEFCON=6
mahlemiut wrote:Description edited. Now we just need Zwaxy to fix MARP to use 64-bit integers now. It should be real easy to break this score in Giga Wing too.
We should indtroduce special rules for giga-wing.
All players (enough to be called a "player") 's ratings are always 49,999,999x when finishing the game at giga-wing.
200 trillion is very easy for everyone who can finish the game without die,without bomb,with 49999999x rate.
300 trillion seemed impossible
so... numbers divide by 50 million as a score of Gigawing.
DEFence CONdition
WAR 1<< >>7 PEACE
sikraiken
Post by sikraiken »
I wouldn't really call 200 Trillion easy. Maybe for you Japanese experts who play the game inside and out, easy.
If the problem doesn't get solved (which I bet it will), I'd say cut off the last 6 digits and stick the actual score in the description. Easier method than dividing and stuff. :)
So the multiplier maxes out at 49,999,999? I don't think there's going to be a lot of people doing that. Not to mention there's going to be submissions by people that CAN'T finish the game on one credit. Then what?
200 trillion isn't easy for EVERYONE ya know... and it's funny that you mentioned 37 trillion too. Who's the stalker now?
MDenham
Post by MDenham »
How about we just update the database to accept 64-bit integers?
How about we find Zwaxy first, seeing as he's probably the only one capable of doing it. Now he must be around somewhere...
