http://marp.retrogames.com/inp/lcf_alib ... _win61.zip
Desyncs and results in 6200 on Win Client and MAME32, worse on Kaillera. Sound option makes no difference.
alibaba
same here, this problem is due to different roms. or non existant ones verses zereoed out ones. we should probably enforce one or the other, i think if you zereo them out you get reasonable colors if you remove them you get crappy colors.
alibaba.7f NO GOOD DUMP KNOWN
alibaba.4a NO GOOD DUMP KNOWN
- roncli
- MARPaltunnel Wrists
Wha? I'm confused.Chad wrote:same here, this problem is due to different roms. or non existant ones verses zereoed out ones. we should probably enforce one or the other, i think if you zereo them out you get reasonable colors if you remove them you get crappy colors.
-roncli
