tetrisp2
roncli
tetrisp2
Post by roncli »
http://marp.retrogames.com/inp/ms_tetri ... _win60.zip
Does not play back at all on 60 or 61, either using the windows client or MAME32, with or without sound. Perhaps it needs to be tried on Win98?
-roncli
sikraiken
Post by sikraiken »
10,710,800 is the actual score. Please someone change it so I can confirm it.
Used MAME 32 .60, sound on, frameskip = 0 until mid of level 1, then F10 and Frameskip 11 after that.
roncli
Post by roncli »
Still plays to zero here, even under those settings.
What are your sound settings, and what OS are you running?
Also, I was able to playback his previous score just fine.
-roncli
sikraiken
Post by sikraiken »
windows 98 se. I ran it in a window (shouldn't matter, should it?), with Directsound 48000 samplerate. FM Synth, Stereo, Use Samples, Use Filter; all selected. Lemme try it on WinXP right now.
Update - Works fine with WinXP, I put it Fullscreen, with Draw Every Frame. If you get a pink piece and yellow piece in that order, not the other way around, on the first level as the first pieces, then it will playback correctly.
roncli
Post by roncli »
Eh? How do you select all that? I can't get it past 44100. :(
-roncli
sikraiken
Post by sikraiken »
Oops. :) I was usin Mame32K(Kaillera) .60 . :) Now I have to try to real one.......ugh. :/
roncli
Post by roncli »
Ahhh... I have that at home. I'll try it there. :)
-roncli
sikraiken
Post by sikraiken »
Maybe some people should get together sometime on Kaillera and play a game or two. That'd be fun. MARP-K. ^_^ :D :)
roncli
Post by roncli »
PERFECT PLAYBACK!!!! Thanx man! :)
-roncli
