Tapper
Tapper
I can´t get this to playback, it gives a sound error when I try to play it in m35b11 dos and it get´s out of synch when I try it in MAME32
http://marp.retrogames.com/inp/sls_tapp ... m35b11.zip
sound appears to be broken in that mame version for this game, and the nvram issue started (i think in the late 35 cycle). This game requires a default nvram file and Does playback correctly for me using dos mame 35b11 (sound on even though it doesn't work) and with default cfg/nvram files existing.
nvram requiring recordings were grandfathered before sep 15.2001, all other recordings uploaded after that will be dqued if nvram files are required to play them back.
on a side note the easter egg recording
http://marp.retrogames.com/inp/waf_tapper_0_m35b5.zip
i could not get to playback. but i also don't know what i'm looking for, the inp doesn't appear to drop a credit.
Can´t playback Russ La Croix tappera recording
I can´t get this to work at all, anybody with more luck then me?
http://marp.retrogames.com/inp/rwl_tapp ... mame55.zip
this one works with dos mame no sound and with a default nvram file, it's better than zereod.
- roncli
- MARPaltunnel Wrists
I can't get any of Storm's to work correctly. NVRAM issue?
http://marp.retrogames.com/inp/kfx_tapp ... mame60.zip
http://marp.retrogames.com/inp/kfx_suta ... mame60.zip
-roncli
Can´t be nvram
I use the record.bat file from MARP when I make a recording, so it can´t be a nvram issue.
all three of these work perfectly using dosmame60 or CLI mame60 and sound and this mame cfg file and with my win98se boot.roncli wrote:I can't get any of Storm's to work correctly. NVRAM issue?
- roncli
http://marp.retrogames.com/inp/kfx_tapp ... mame61.zip
Using the provided .cfg file, I was unable to playback any, including this new one.
-roncli
