Now all you have to do, for example, if you want to play amidaru using a changed TG settings set, you would just type this:
m35tg3 amidaru -record amidaru
This line will play the game using the settings that were saved in the CFG file.
If you use MARP's recording BAT file, it would essentially delete the CFG and HI score files, resetting the settings to default, and that would not be good.
Hopefully this will help all of you out - good luck!
goldengameboy@yahoo.com
