How can I play with the speed-up cheat of a game, using Wolfmame?
With MAME i can activate cheats, to play for instance "Jr. Pac-Man [with speedup cheat]" .... but with Wolfmame is possible? Or in this case i can record with normale MAME ?
Play with speed-up cheat
Antonino Sollena
Re: Play with speed-up cheat
With Wolfmame you can still use any cheat, or save/load savestates...unless you're recording an .inp.....
You cannot play with speedup cheat. We know there were games on location with the speedup chip in them (so ms pacman was perma fast), but as far as I know, no currently accepted mame version for MARP will play those roms.
https://PrivateLadyEscorts.com - Where To Local Private Lady - No Selfie - Anonymous Adult Dating - Anonymous Dating Chat
- Flobeamer1922
- Button Slapper
There do exist clone ROM sets for Pac-Man, Ms. Pac-Man, and Jr. Pac-Man with the speedup chip (puckmanf, pacmanf, mspacmnf, and jrpacmanf).
Entries have been made for this mode by the past, then archived (I don't remember exactly when and why).
But they are still there on Marp, and you can still upload inputs, even if they won't count for LB :
• *hangly-fast (Hangly-Man (set 1) [with speedup cheat]) #1st : 804570 Rick Carter (100%)
• *hangly2-fast (Hangly-Man (set 2) [with speedup cheat]) #1st : 591790 Rick Carter (100%)
• *hangly3-fast (Hangly-Man (set 3) [with speedup cheat]) #1st : 923440 Rick Carter (100%)
• *joyman-fast (Joyman [with speedup cheat]) #1st : 615780 Rick Carter (100%)
• *jrpacman-fast (Jr. Pac-Man [with speedup cheat]) #1st : 1364290 roncli (0%)
• *mspacmab-fast (Ms. Pac-Man (bootleg) [with speedup cheat]) #1st : 846520 Rick Carter (100%)
• *mspacmat-fast (Ms. Pac Attack [with speedup cheat]) #1st : 627170 negative1 (100%)
• *mspacpls-fast (Ms. Pac-Man Plus [with speedup cheat]) #1st : 755760 negative1 (100%)
• *newpuc2-fast (Newpuc2 [with speedup cheat]) #1st : 937200 Rick Carter (100%)
• *newpuc2b-fast (Newpuc2 (set 2) [with speedup cheat]) #1st : 444600 Rick Carter (100%)
• *newpuckx-fast (New Puck-X [with speedup cheat]) #1st : 1000000 Rick Carter (100%)
• *pacgal-fast (Pac-Gal [with speedup cheat]) #1st : 806680 TK2012 (0%)
• *pacheart-fast (Pac-Man (Hearts) [with speedup cheat]) #1st : 3237880 Rick Carter (100%)
• *pacmod-fast (Pac-Man (Midway, harder) [with speedup cheat]) #1st : 1053010 Rick Carter (100%)
• *pacplus-fast (Pac-Man Plus [with speedup cheat]) #1st : 546050 Rick Carter (100%)
• *piranha-fast (Piranha [with speedup cheat]) #1st : 217420 Rick Carter (100%)
• *piranhah-fast (Piranha (hack) [with speedup cheat]) #1st : 401150 Rick Carter (100%)
• *piranhao-fast (Piranha (older) [with speedup cheat]) #1st : 393800 Rick Carter (100%)
• *puckmana-fast (PuckMan (Japan set 2) [with speedup cheat]) #1st : 1304260 Rick Carter (100%)
• *puckmod-fast (PuckMan (Japan set 3) [with speedup cheat]) #1st : 2899810 ccr (100%)
francoisadt1
- Button Masher
What do you mean by "counting for LB"?
The only way to play these tracks which do not have a clone version of the original ROM,
is to have the original ROM with cheat enabled equals to fast (2x or turbo).
