Psychic 5
Psychic 5
Back in 0.130, a "World" romset was added to Psychic 5, and the existing Japanese version was made the clone romset. The existing scores for this game have not been moved from psychic5 to psychic5j.
http://replay.marpirc.net/r/psychic5
http://replay.marpirc.net/r/psychic5j
Every score here should be moved to psychic5j except for The Onion Knight's score of 475,700, as it was recorded with wolf141.
The only existing score on MARP right now for the psychic5j romset is utomood3's 18,043,400 score (http://replay.marpirc.net/inp/c/c/b/uto ... olf130.zip), which was of course actually done on the same Japanese version as his 19,130,300 score, so the 19,130,300 score needs to overwrite the 18,043,400 one.
Re: Psychic 5
Post by ***PL*** »
Matt, you are correct that the clone for Psychic 5 was added in m130. However, the ROM swaps actually occurred later with m158. Let in look into this some more and I will fix it.
Re: Psychic 5
Post by ***PL*** »
OK, I swapped all the psychic5 and psychic5j INPs. Since the ROM changes occurred at m158 and NOT m130, and both the Onion Knight (m141) and utomood3's (m130) INPs were recorded prior to m158, neither required the extra swap back.
Re: Psychic 5
***PL*** wrote:Matt, you are correct that the clone for Psychic 5 was added in m130. However, the ROM swaps actually occurred later with m158. Let in look into this some more and I will fix it.
whoops, my bad!
