Vignola Renzo - tp84b - 413,300
Cicca
Post by Cicca »
It has been played at "Normal" difficulty, where default is "Hard"...I'm afraid it has to be zeroed....
Re: Vignola Renzo - tp84b - 413,300
Cicca wrote:It has been played at "Normal" difficulty, where default is "Hard"...I'm afraid it has to be zeroed....
How do you see the difference ?
Cicca
Post by Cicca »
You can compare his game with the BBH's one, or mine (I just took the 1st place... :mrgreen: ), that are played with hard difficulty....look for example at the heavy enemies (those to be targeted and destroyed with missiles)....from stage 2 to 6....with normal difficulty settings they come in waves of 2....when hard is set, they come in waves of 3....
Ok Antonio, I trust you on this one, I'm not very familiar with the game.
Score has been zeroed
Ok Antonio, I trust you on this one, I'm not very familiar with the game, and it looks that you know it well :)
Cicca
Post by Cicca »
Thanks Phil....I do actually own it !!! 8)
BTW....I guess that those dip switch settings could be easily verified by some "low level confirmer" inspecting the .inp file....while it's sometimes hard to detect just watching the game replay....
You can with more recent versions of Wolfmame (type -iv in your commandline, then press DEL when playing back and you will see the dips used)
Cicca
Post by Cicca »
Thanks for the hint.... :idea:
