I can playback...but I can't play !!!
Cicca
Post by Cicca »
Hi,
How could it be possibile to be able to playback an .inp, but not to play with the same romset and the same emulator version....?! 8O It's happening to me with pbobbl2n and wolfmame 0.169....I can watch an inp, but when I start a game, it says me there are some ROMS/CHDS missing.... :roll:
Thanks for any hint....
Re: I can playback...but I can't play !!!
I can only guess that on playback, you're using a BIOS that you have, but not the one set for normal play. Either check for a game/system specific INI (neogeo.ini or pbobbl2n.ini), or failing that, get an up-to-date BIOS set (neogeo.zip). -verifyroms will check all BIOS roms, so can give a NOT FOUND error even if you have some working BIOS which will run the game.
Cicca
Post by Cicca »
I also tried to record an .inp, using the provided .bat file, and I managed to....
I the copied the 2 roms (pbobbl2n and neogeo) in another MAME version folder, and it started from the gui....
I actually don't know what's wrong....but I can workaround it, so it's fine.... :wink: ... I doubt I'll ever play that game again afetr Yolimpics2016... :P
