Does not play back at all for me. Puts one credit in but two are required to start. I see lots of input afterwards but the game never starts.
I tried it with one credit already in the machine, but it desyncs quickly and loses in the second match.
Amarauma - UMK3 - 327
Re: Amarauma - UMK3 - 327
Same for me
Sounds like NVRAM to me.
Amarauma, INPs must start with no NVRAM files present, so that it is easy to play them back. Any changes to settings with games that store settings in NVRAM must be done at the beginning of the recording.
Okay. Learning yet.
Another score was send. No nvram this time.
Looks like you forgot to remove NVRAM on hsf2a also.
http://replay.marpirc.net/inp/8/3/2/amr ... olf169.zip
Probably. I use Emuloader, is a easy way to configure to no nvram?
add to the commandline -nvram_directory NUL
or create an empty txt file called "nvram.txt" in the directory where you have mame.exe
then erase extension ".txt" and no more nvram folder will be created
Okay. the second way look good to me.
Thanks.
Thanks.
