Wolfmame 164
- simpsons99
Wolfmame 164
I downloaded and installed Wolfmame 164 this morning ..
Anyone else having problems getting it to start the rom from recording? a quick message comes on screen and everything goes away ..
I know the roms are good I tried them by just click on mame to play
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
yeah , i was able to get
avefenixl
pheonixass
to work.
But unable to get bzaxxon and jungler (bandi),
a screen in dos,(the one simpson99 refers to )that gives the closest matches pops-up.
avefenixl
pheonixass
to work.
- simpsons99
Re: Wolfmame 164
I even tried Phoenix that has been out a long time .. It did the very same thing
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
Please run from the command prompt, that way you can see what errors may be occuring.
- simpsons99
Re: Wolfmame 164
there is no other way to record a inp then doing it that waymahlemiut wrote:Please run from the command prompt, that way you can see what errors may be occuring.
Arcade Game Scores
Arcade Game Scores
- simpsons99
Re: Wolfmame 164
ok the problem is the record file that was made for me from here .. No longer works with wolfmame 164 for some reason ..
I tried with the record that came with the mame it quickly goes from the black screen to the list of games .. Then does not record anything it stops when rom loads ..
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
Not sure what's so hard here...
record <game shortname> <INP filename> [option extra switches]
Visual aid (ignoring the fact that I'm not using Windows):
http://mahlemiut.marpirc.net/console.png
- simpsons99
Re: Wolfmame 164
mahlemiut wrote:Not sure what's so hard here...
What is so hard? The black screen quickly posts the message and closes .. There is no time to get what it is saying at all..
Everything has worked fine with 163 what did you change with 164?
Please do not treat me as I am dumb alright?
If this is not figured out I will be retiring and not using anything after 163
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
Stop double-clicking the record batch file like it's a regular program on your desktop. That's not how it's meant to be used, and it's obvious you're using it that way. This has been explained to you numerous times, with visual aids and step-by-step instructions. It's now up to you to figure it out and stop blaming other people. Or retire.simpsons99 wrote:mahlemiut wrote:Not sure what's so hard here...
Re: Wolfmame 164
Apparently, running something from the command prompt is. You'll see any actual errors that way.simpsons99 wrote:What is so hard? The black screen quickly posts the message and closes .. There is no time to get what it is saying at all..
- simpsons99
Re: Wolfmame 164
I do everything like I did before.. Your lack of understanding is a huge problem .. Get a clue !mahlemiut wrote:Apparently, running something from the command prompt is. You'll see any actual errors that way.simpsons99 wrote:What is so hard? The black screen quickly posts the message and closes .. There is no time to get what it is saying at all..
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
Only thing I'm understanding is that you're using a batch file as if it were a desktop application. The clue is, it isn't. I cannot diagnose an issue if I don't have any information.simpsons99 wrote:I do everything like I did before.. Your lack of understanding is a huge problem .. Get a clue !
- simpsons99
Re: Wolfmame 164
mahlemiut wrote:Only thing I'm understanding is that you're using a batch file as if it were a desktop application. The clue is, it isn't. I cannot diagnose an issue if I don't have any information.simpsons99 wrote:I do everything like I did before.. Your lack of understanding is a huge problem .. Get a clue !
Well I have always did it this way without any problems .. Now with 164 bang it does not work .. I guess I will not be playing anything that comes out after 163.
I know this is a complete joke to people it should not be .. Please Ban me from here .. Respect me or get rid of me Thank you very much.
Arcade Game Scores
Arcade Game Scores
Re: Wolfmame 164
The only thing I can suggest is that you check what executable is being loaded - the exe filename changed to mamearcade.exe from 0.163. But since you said it worked in 0.163, I can dismiss that as a possibility, right?
I have been fair and reasonable, I can not tell you what is wrong by telepathy.
