Butasan
Butasan
All these old butasan scores will need to be moved to butasanj. butasan is now an English language version added a few versions back (about 8 months ago).
Re: Butasan
Right :
0.143u7: Bensonrad added 'Butasan - Pig's & Bomber's (Japan, English)'. Changed 'Butasan (Japan)' to clone '(Japan, Japanese)'. Renamed (butasan) to (butasanj).
I won't move all inp, the best way is to let Pat make the renaming (butasan --> butasanj)
While updating 0.144 he probably didn't see the renaming, and only created "butasanj"
Re: Butasan
Result is now butasan INPs are correctly under bujutsu
Re: Butasan
???***PL*** wrote:Result is now butasan INPs are correctly under bujutsu
Re: Butasan
Should have said, FIXED!!
INPs are now effectively moved where they need to be!
Re: Butasan
bujutsu is a completely different game (Fighting Bujutsu)... they were supposed to be moved to butasanj
Re: Butasan
You're right! I had too much tequila last night. Fortunately, no one has played bujutsu, so I will move them to butasanj as originally requested.BBH wrote:bujutsu is a completely different game (Fighting Bujutsu)... they were supposed to be moved to butasanj
Re: Butasan
Everything is perfectly fixed now, thanks Pat
