How can I start to record a game with FS10 or FS9 using wolfmame 0,137 or older versions?
How can I enable joystick? I just use keyboard because the controller not works.
I have problem with it and that is the reason that I tried to use Gui version for submissions.
Frameskip and Controller Issue
- Button Slapper
Rodrigo Lopes
Metroid Team, from BRAZIL
South American World Champion
Re: Frameskip and Controller Issue
Add -frameskip 10 and -noafs to the commandline.Siliconian wrote:How can I start to record a game with FS10 or FS9 using wolfmame 0,137 or older versions?
Add -joystick to the commandline.Siliconian wrote:How can I enable joystick? I just use keyboard because the controller not works.
As a more permanent alternative, you can edit mame.ini (with Notepad or any other text editor) and change the relevant options.
If you must have a GUI, then you can always use M+GUI, available from the MAME Plus site (http://mameicons.free.fr/mame32p/ - under "Experiment Projects"). Please try to avoid using MAME Plus itself, however, as INPs created with it are incompatible with MAME and WolfMAME.Siliconian wrote:I have problem with it and that is the reason that I tried to use Gui version for submissions.
- Button Slapper
Wonderful help guys!!!
I will re-submit missing scores with M+GUI, maybe now will works fine!
Thanks
Thanks
Rodrigo Lopes
