http://replay.marpirc.net/r/bubblem
http://replay.marpirc.net/inp/6/1/b/lig ... win133.zip
Goes out of sync quickly. For bubblem you must hit F2 before every recording if you are recording correctly after removing the mame/nvram/bubblem.nv , but i think there is more than just that at work here. Also you can't take first place with a regular mame recording, you need to record again with wolfmame to be at 1rst.
Bubble Memories
Bubble Memories
Re: Bubble Memories
Immediate out-of-sync messages often indicate MAME Plus was used. That being said, still no pushing of the test switch, suggesting that NVRAM was used.
Re: Bubble Memories
playback 1 frame then goes out of sync for me also...
Re: Bubble Memories
Same for me, score zeroed
