New and some questions, pls look at my manifest.xml for inp
Posted: Sat Mar 14, 2009 9:26 pm
Hello to everyone. I am new to Marp and this site. I have some questions.
A note: I am not a power player, so please don`t be dissapointed if you see anything from me.
Another note: I am new to WolfMame. Before then, I used Mame32 ... and then original Mame with command line interface.
post edited ...
- Will be uploads to marp accepted, if the archive contains other files such as bitmaps (screenshots) and textfiles and xml files describing the record also? I have a standard procedure, which packs everything I need into an archive. Would this be accepted? Or should the archive contain the input file only?
- Currently, I have Mame and WolfMame at version 0.125 (Windows). Since then, I did not many records (in fact, only a handfull). I am currently not sure if I should update to the newest version 0.130. My problem at updating is, that I have a mass of roms and chd files. They are not all compatible with the newer version, so ... For recordings, would it be better to update or not? What are the pros?
- Is WolfMame available for Linux or other systems?
- Why doesn`t WolfMame generate the .wlf file anymore?
post edited ...
