MAME KNOCKOUT CHAMPIONSHIPS 6
- Marco Marocco
- MARPaltunnel Wrists
KNOCK OUT 6TH EDITION
MarcoMarocco, GameBoy9 and Sawys proudly announce the 6th edition of the MAME Knockout Championships (the real MAME World‘s Championship).
We've made some changes in the format and we hope to involve a great number of players !
Prizemoney : 350 € bonus for the winner, 155€ for others results [5€ for high score for every game from the beginning to the final (45€ total);
10€ for high score in the 1st stage. (3 games combined) (25€ total for stage 1, 5€*3 for the games above, plus 10€ for the high LB score); 25€ for reaching the "round of 4" (50€ total); 50€ for 2nd place; 350€ for 1st place] offered by Marco Marocco and payable not later than 28th February 2008.
Who doesn't like the prize money can donate it to MARP !
The Knock Out 6th edition will start at 21th of September, h. 00.00 GMT.
General guidelines for submission:
- In order to enter K6, it is sufficient to send your inps to MARP with the subscription ”K6” after the start of the championship; in every case, we will open a topic on the forum entitled “K6 list of players”, in which every player can announce (not forced, but pleasant) his partecipation, showing the country that s/he comes from.
-For this tournament, we will only accept WolfMAME Plus 0.106. Other versions of WolfMAME will be permitted and indicated by the Coordinators only in the event that a game is discovered to have severe emulation/playback problems.
-When submitting, please be sure to include the .wlf file along with the .inp.
-It is strongly encouraged to use the game's shortname as the filename when you submit your .inp/.wlf file. Long filenames can be a hassle for confirmers.
-As is the case with regular MARP rules, only one credit is allowed. No continuing, and no starting a 2nd game after your 1st credit.
-Recordings must be submitted within 48 hours of creation, except for the last day of competition on a round, anything submitted on the last day must be uploadedwithin 24 hours of playing.
-Unless otherwise noted, all games are to be played on the default settings. If you're not sure your settings are default, delete the game's corresponding .cfg file from the cfg directory. Although they are usually accepted at MARP, recordings on "harder" settings will not be permitted for this tournament. If the game uses a bios file, please make sure that it too is set to "default", playing on a different bios can lead to playback problemsand sometimes results in changes to gameplay as well.
-Final time before which a recording must be submitted to MARP is 23:59 GMT on the corresponding day. If MARP is down for an extended period of time, we will accept submissions via forum attachments on the thread for that week's game. Please do not submit recordings to the forum if MARP is not down.
-There is no limit to the number of times you may submit on a game, as long as your new recording is a higher score than the previous recording. Regular uploading of scores is strongly encouraged since it makes for more interesting competition.
-Average recorded speed must be 95% or higher. Use frameskip if you must.
-If none of the three tournament coordinators can play back your recording, then your score will not be accepted. To help ensure that your recordings will work,please make sure that you delete/disable your nvram directory, and in the case of Neo-Geo games, delete/disable your memcard directory as well.
THE FORMAT
1ST STAGE: MASSIVE ELIMINATION ROUND
We decided to remove the qualifying round, it was only helpful to know the number of players.
The championship begins with one elimination round who goes on for three weeks, one game for each week (7 days with a 24-hours period separating each week). The games will be announced week by week.
Players do not necessarily have to enter te championship on the first week, it’s possible to join the championships also from 2nd or 3rd week (of course having few chances to go on !).
For each week there will be a classification, with the following point system: 70 pts for 1st place, 60 pts for second place, 55 for third place, 50 for fourth place then one point less for following positions till reaching one point (53 th place).
Top 36 move on, the seeding for next phase will be determined making the addition, for each players, of the scores got in each week.
In case of tie will pass the turn the player who has higher position in the tree weeks (exemple: 2 players have 80 pts; one has got two times 3rd position, the other has got one time 1st position then other lower positions. The second player, who has 1st position, pass the turn).
2ND STAGE: ONE ON ONE (36 PLAYERS)
Top 18 against players will be seeded according to the results in the first three rounds. The rest will be seeded randomly. Winner moves on, loser goes home!
3RD STAGE: ELITE ELIMINATION ROUND (18 players)
One week to reduce the number of the players to 12: top 4 get a bye and, therefore, a week rest for stage 4.
4TH STAGE: ONE ON ONE FOR PLAYERS FROM 5TH PLACE TO 12TH PLACE (8 PLAYERS)
Matchups will be 5 vs 12, 6 vs 11, 7 vs 10, 8 vs 9, winner moves on, loser goes home from this point forward.
5TH STAGE (QUARTER FINAL) 8 PLAYERS
6 TH STAGE (HALF FINAL) 4 PLAYERS
7 TH STAGE: FINAL 2 PLAYERS
THE FORMAT
Prize money, great.
IMO 1st stage elimination should be different. 36 players advancing is way too much. How do you know there even will be 36 players? That kinda makes 3 weeks of playing with no real threat of elimination...that's not good for seedings either, players will not try their best on stage 1.
I suggest:
- 1st stage elimination cuts the number of players to 18(hopefully there are more than that active participants)
-drop 2nd stage elimination completely, start from stage 1 and then skip to stage 3 with 18 players.
Edit: Well, it looks like there will be enough players.
I suggest:
- destructor
Re: MAME KNOCKOUT CHAMPIONSHIPS 6
Yes, I love it in KOMarco Marocco wrote:Winner moves on, loser goes home!
- Marco Marocco
During K5 (and with other games too) I experienced problems using Wolf106 on Windows98 platform, some kind of memory allocation failure launching the program, in fact most of my inps were made with Wolf101.
Now it's not a problem for me anymore, because I've got a second PC with WinXP, but I wonder if there is a known problem with old systems that has risen between version 101 and 106.
I think people with Windows98 systems should try to play some random games with Wolf106 in these days to see if they experience problems too.
I done a lot of playtesting on K5 on Win98. The only one does works on Wolf106 is using CLI instead of GUI. Most of the games will work on CLI better, but not all of it. GUI does random crashes, but I can't guarantee it will work in some games.
My suggestion is you guys to inform K6 coordinators if you are using Win98 or ME and they *should* give you the alternative WolfMame to use. Wolf101 is preferable and it is up to them to decide which alternative WolfMame is available.
BTW, I don't see the rules about minimum CPU's requirement to play K6. Good Luck K6 coordinators... I give you guys another * sigh *.
NotMan
NotMan
- Marco Marocco
"Other versions of WolfMAME will be permitted and indicated by the Coordinators only in the event that a game is discovered to have severe emulation/playback problems"
We can add: "other versions of WolfMame will be permitted and indicated by the Coordinators also when WolfMAME 106 doesn't work properly wth your p.c."
- destructor
- Marco Marocco
Sure: Destructor, Kaiser, Mahlemiut, NotMan, Metrackle, Adder, myself... Ok, most of those are MARPers that are members of Rotaxmame as opposed to the other way around. I'll ask Adder to post an announcement for the KO on Rotaxmame in Czech and we'll see if we get any crossover.Marco Marocco wrote:Is any member of Rotaxmame a marperdestructor wrote:Interesting if rotaxmame guys will play in KO
ewww...why would you delete the older ones? just burn to CD(s).zarouk wrote:hi,
do you think it will be possible to use Wolf 0.118 ?
I've update recently all my set to 0.118 and i think 0.106 is too old ( 15 may 2006 !!!! )
Hope it will be possible.
given most sets are same...only the discontinued/changed ones would need that backup.
0.118 is 2-3 times slower for many games than 106 is...at least that is how I see it on my system....test something like pacman to see.
106 I can run that at 650%...on 116(likely same for 118), I only get 250%.
2.5 times slower...
I only get about about 10-20% drop in Dungeon Magic (Taito-F3) from 0.106 to 0.118. And using Direct3D is faster than DirectDraw.
With Pac-man, it drops about 50%, but DirectDraw is faster than Direct3D. Not that there's much difference between 550% and 610%.
And it's common knowledge that MAME gets slower as it focuses more on more powerful hardware.
...and why does MAME try to access a DNS server when using DirectDraw, anyway?
