Vitrua Racing (vr)
Vitrua Racing (vr)
http://marp.retrogames.com/inp/2/2/2/dg ... olf115.zip
http://marp.retrogames.com/r/vr
Goes out of sync close to immediately, this must be a mame issue with the 2nd place wolf114 recording still playing back fine.
gameboy9
Post by gameboy9 »
I had the same problem - it desynced after the first turn for me, I think.
http://gameboy9.marpirc.net
one more to verify unplaybackability?
zlk
Post by zlk »
It does not work for me either.
Blost
Post by Blost »
same here.
must be some nvram issue or something because recording works fine with 0.115, made some tries...
DGO
Post by DGO »
I can confirm... It's a nvram issue... It plays back fine with the original nvram..
This one definately needs to be recorded without nvram..
Back to work for me..
thanks for checking
ALL games should be recorded using the no nvram use feature of wolfmame.
Use it on playback of your inp to get your high score on the table for games that it doesn't interfere with playback.
DGO
Post by DGO »
LN2 wrote:ALL games should be recorded using the no nvram use feature of wolfmame.
Yes, I know, thanks, however, with many games it doesn't matter and they playback fine. By feature you mean using the batchfile or setting the nvram dir to NULL right?
LN2 wrote: Use it on playback of your inp to get your high score on the table for games that it doesn't interfere with playback.
I don't fully understand your sentence here, but yes, I should use the playback.bat file or kill the nvram files before replaying and check playbackability before uploading :oops:
Anyways, once MARP is up again I'll submit a good recording :)
