Hello everyone:
I just tried to submit a new score which is an improvement over one I successfully submitted this past weekend and received the following error message...
some kind of error with the zip file - couldn't unzip it
command: './exe/unzip -l rtm_ghoshunt_32120_wolf101 2> /dev/null'
correct the bad stuff and resubmit, or whinge to
I am using the same version of WolfMAME, and using MARP-preferred file naming conventions for the INP, WLF and even the zip file itself ("Ghoshunt.extension") and keep getting this error message even after re-zipping the files. All of this worked less than 2 days ago but not now.
What are my options at this point ? Thansk.
Robert
Error in Submission
And Valter has a 35k that he will probably be submitting, which Robert already knows about.Phil Lamat wrote:Hi Robert ...
You can keep on playing, I have a34k+ input to submit (as soon as ztnet will work of course)
http://www.twingalaxies.com/index.aspx?c=22&sid=86052
