Triple punch leeching
Seems to be able to leech easily because time-count being over doesn't be a mistake.
- triplep_wolf104.zip
- easy leeching?
- (67.94 KiB) Downloaded 200 times
I want to refer the following.
viewtopic.php?t=12375
I think that it looks like the case of round-up well.
In both cases, I think that it can earn it without the limitation of time.
However, it is easy or is difficult to differ.
I am hoping to add a special rule to both.
round-up and triple punchi.
I think that you must not exceed time-counter...AND follow inp will disqualified.
http://marp.retrogames.com/index.cgi?mo ... per_game=3
- destructor
Wait a while, I must back to this game.The TJT wrote:Des, maybe you know something about round-up?
EDIT
Round-up.
As I said before I accept each rule for this game. But remember, infinite leeching is very hard to do here. Enemies are faster with every second. Doesn't depend it is on first or next stage. If you show me replay with score 500k on one life on one stage then I can say that yes, infinite leeching MAYBE is possible, made 2 millions and then I say, yes infinite leeching IS possible.
And yes, otherwise every can beat my score from 1st on first stage only. My best score using 1 life on stage 1 if I good remember is about 120-150k.
If we want interesting replays we can made special rule about finishing stage before time is 400.
Second option is bonus points for every finished stage.
And remember, for this game special rule isn't required. I can made identical high scores using leeching and without leeching.
If we want to make betters scores than on TG I for not add special rules. I can reach the same stage using 1 life or all life. I use all life to maximize score on stage 1 and next go throught next stages without leeching.
Maybe better don't use special rules at this time for this game. If somebody made 2mln or more using leeching we will back to this problem.
Triple-Punch
I watched dan's triple-punch replay, I see you died because two enemies go to you from two different sides. Then here is hard to say about infnite leeching too. Show me inp with 500k and I say yes, inifinite leeching is possible:P
And as for round-up if we want interesting replays special rule about timer can be added.
Bonus for every finished stage is useless in this game beacuse I see that enemies are very slow here.
As for roundup we can wait until somebode submit very very high sore using leeching and next back to this topic.
