Page 1 of 2
9.999.999 to the flicky
Posted: Mon Feb 20, 2006 3:35 pm
by JLr-DF
First congratulations VERTEX-DAN. I´m play this game for 6 years and I have never seen anybody play so well.
I love how you play this game, is perfect. you lost lives only because you have a little mistakes.
But I saw in replay than when you make 9.900.000 your points back to 9.8000.000 always.
I don´t know if this is a bug of game or the game don´t stop in 9.900.000.
I sugest to Editors than all people than do more than 9.900.000 like VERTEX-DAN did. The record will be change to 9.999.999 or 9.900.000
Now, I will try to do this to
Posted: Mon Feb 20, 2006 6:28 pm
by TRB_MetroidTeam
Nice to see you here again, JLR! Let's play man!!!
Posted: Tue Feb 21, 2006 7:33 am
by JLr-DF
yes, I´m back
. Play again.
But I think than Flicky needs Special Rules
Posted: Tue Feb 21, 2006 8:38 am
by dan
Thanks JLr.
Exactly,I think that 9,826,080 is not an accurate score.
A special rule might be necessary for this game.
Posted: Tue Feb 21, 2006 11:15 am
by JLr-DF
How want than when someone do 9.900.000 in flicky, this record be edit to 9.9000.000 or 9.999.999.? because the score in game stay beteween 9.800.000 and 9.900.000 forever.
I vote yes
Posted: Tue Feb 21, 2006 3:27 pm
by The TJT
Hard to come up with special scoring...After 9,9M score rolls between 9,8 and 9,9...So it IS possible to count the correct score, but it requires counting how many times 9,9M is broken. A bit tough for playbacker.
Counting rounds does not help either, since "meter" locks at 99.
According to some other games, as Galaga, Tron and whatever where score rolls at 1M, we should just count the correct score at Flicky too...although it is much more more worky at Flicky.
So I'd say that Dan could edit hes score to the correct one.
Nice inp btw. Somehow this one brings to mind words "happy game"
Posted: Tue Feb 21, 2006 5:39 pm
I think that the best options are:
1) Final score, as entered into the high score table,
2) The highest score shown in-game,
3) The maximum possible. ie: 9,900,000.
I'd tend to go for either 1 or 3, as they are the easiest to determine.
Posted: Tue Feb 21, 2006 6:04 pm
by The TJT
There's not much diffrence:
1. 9,83M
2. 9,896M
3. 9,9M
...And difference is not "real" (doesn't differentiate correctly scores over 9,9M.)
Are you against for submitting the "correct"(13M) score, because of trouble with having to count when confirming?
I don't think it would be a big trouble, since not so many will break 9,9M.
Posted: Tue Feb 21, 2006 7:01 pm
Good luck counting then.
If it rolled back to 0, then sure, that's easy to follow, but not so easy trying to count up a quick few hundred thousand.
Posted: Wed Feb 22, 2006 9:31 am
by JLr-DF
TJT the record is not real, but the leadebord don´t know about it. If I make 9.8900.000 and lost the last live. Are better than Dan. it´s not correct.
I pefer the option number 3 of mahlemuit.
Posted: Wed Feb 22, 2006 8:09 pm
by The TJT
Ok, you can do what you want...But if anybody beat Dan, then just change score to 13M... Good night
the reason
Posted: Thu Feb 23, 2006 7:55 am
by JLr-DF
That´s the reason of this topic. A special rules on flicky.
If the max point will be 9.900.000 the record of dan will be edited and nobody will beat this record only make the same.
Posted: Thu Feb 23, 2006 10:44 am
by INNUENDO
Good ideas, Barry!!!
Well, I think the suggest number 3 is better. Could be, guys???
Posted: Thu Feb 23, 2006 6:08 pm
by dan
I think 3rd is better.
Or,the maximum value that can be displayed 9,899,990.
Posted: Thu Feb 23, 2006 6:52 pm
by The TJT
dan wrote:I think 3rd is better.
I think it's up to you which score you choose to use.
They are all valid options. I was concerned that what if many make max score...will it be one more of those shared 1st places, which should be something to avoid leaderboard-wise and whose-score-is-the-best-wise.
However, if you choose to show the real score of about 13 ? millions, I promise to playback it with pen and paper and to confirm it myself.
