Amerdart/amerdar2: Split needed
Split this into sector shootout and flash. I wouldn't put "high score" in only because it's too easy to get perfect score. Flash isn't as easy, and sector shootout scores vary by where the sector is.
If you ask me, all scores that equal should not get LB points. Even Pacman.
There should not be a game from which you get LB points eternal.
(example, you beat any Phoenix score...I can NEVER be certain for LB points at that, it's allways a game someone can challenge)
Easy or not, there are about 1000 players that can do it after some try...(Flash) Guess this will be archived once someone gets 42k. Not that easy
