1) The replays must be made with Wolfmame version 99 or newer. You must use the default M68k C-core. I also have to be able to get the inp to playback. I am not eligible for my own bounties. If I make any replays that would have won a bounty, it does not matter. The bounty is still available until someone else submits a recording satisfying the requirements of that bounty.
2) All the normal rules of MARP apply. You must play the games with default settings. However, if a game has a dipswitch that lets you use autofire, you may turn it on. (for example you can hit f2 in donpachj to go to the test menu and turn autofire on) If you do use in-game autofire for the replay, please either post the replay here in this thread as an attachment, or post a link where I can download the replay from.
3) You can win two bounties with one single replay. For example if you finish both loops donpachj and score over 26,000,000 on the first loop you get $100.
4) I reserve the right to disqualify anyone, at any time, for any reason.
5) The bounties expire September 1st, 2006.
Here are the games and the bounties:
ROM: smashtv
a) Finish the game on one credit: $100
ROM: donpachj
f) Finish the first loop with the a-ship with a score of 26,000,000 points or higher: $50
g) Finish the first loop with the b-ship with a score of 26,000,000 points or higher: $50
h) Finish the first loop with the c-ship with a score of 26,000,000 points or higher: $50
ROM: ddonpach
i) Finish the game on one credit: $50
ROM: toobin
j) Finish the game on one credit: $50. You may use the first two warps to advance through the game.
ROM: zingzip
k) Clear the first two loops of the game: $50
ROM: tempest
m) Score over 2,000,000 points: $50
ROM: 720
n) Score over 450,000 points: $50
ROM: xevi3dg
o) Finish the game on one credit: $25
ROM: brvblade
p) Finish the game on one credit: $25
Good luck, you'll need it......
