Please, marpers, I need your help.
INNUENDO
Post by INNUENDO »
First, sorry for put this message here, but I didn´t found a current place to post this...
Well, it´s about MARVEL VS CAPCOM 2 for Dreamcast. Anybody knows, how can I have the green and the blue points in the japanese cd??
Because I don´t know how can I enable all the characters... What´s the "sequence"?
Thanks!!!
Did you read FAQ on http://www.gamefaqs.com. I see that there is FAQ and codes for Marvel vs. Capcom 2 for DC.
Japanese DC version... you might be out of luck.
IIRC, to earn one of the point types to use in the shop, you had to play online matches. Since only the Japanese version had netplay and required you to play on Japanese servers (I think), that's bad news for anyone outside of Japan.
And then for the other point type, you had to actually play matches in the arcade. The Japanese arcade version had a memory card slot for you to plug a VMU into, and then playing matches in the arcade would build up points for your VMU. Again, another Japanese-only thing.
So, you have two options... download a savefile containing all 56 characters from gamefaqs.com, assuming your DC has net access to download it in the first place. The other option... find the US version of MvC2. :P
INNUENDO
Post by INNUENDO »
Oh, thanks Destructor for your attencion. :) I´ll go there!!!
BBH, thank you so much. The case is this: One friend of mine, has a DreamCast on arcade system. But he can´t enable the characters and he asked me help. To tell you the truth, I don´t know almost nothing about this game (I´ve played it only 4 times) and about the dipswitches of it.
For this I´ve searched for you... So, he need to use a MEMORY CARD, play a lot to enable them and using SAVING? I understood what you told, but this can be a nice solution too?
I think you understand my problem 100% now. :) Thanks again.
I´ll go to gamefaqs anyway. But before, BBH, answer about this new question, please. Thanks again for your help.
Hi Innuendo...
MvC2 japanese version??? Two ways... go to Japan and play at the arcades with VMU slots... or try to download it from GameFAQs with all the options allowed (I am not so fan of this last one, but in this special situation, is THE WAY).
I own the "USA" version... just play in the Dreamcast (mainly Arcade Mode, to finish the game, getting more points) and buy the secrets with the earned points. :)
Round 1... Fight!
T+
INNUENDO
Post by INNUENDO »
Oh!! I´ll do this, Valter!!! Thank you so much!! Obrigadão, manowww!
Thanks BBH and Destructor. Was nice count with you. ;)
Flw.
Innuendo...
(off-topic... as well as your "off-board" topic, hehehe):
Are you playing to TG DECA 2005?
INNUENDO
Post by INNUENDO »
Off-topic: TRB, no... Because I´m very bad in all games. I´ve tried to play them, but without lucky. I forgot to tell this for you.
And, I´m trying to do 9.999.900 on Jail Break. It´s my biggest challenge in these days. I think MORENO gave up too... :( :cry:
Innuendo... I also sux in that very old games... do you know my preferences... however I tryed mainly 2 games (timeplt and zektor), and being better than my prior previsions, I get some pretty good records at this moment. Maybe your situation would be the same if you re-try a couple more... or maybe not. :(
I am needing to play T9 games too... great doubt!!! :roll:
INNUENDO
Post by INNUENDO »
You´re right! But I´m playing very bad... Looking the T9-Leaderboard, I think I could be one of the lasts...
No problem in play or the games... But I´m playing without good techniques. For this I gave up...
naww innuendo, if you look at your percentage (95%) you could at least place 3rd! especially since your only login you say you are bad at playing, assuming you maybe average to bad in the other games :) give it a try, you have a good arcade setup!
Chad is correct!
Go Innuendo, go, go, go!!! We know your potential, man!
Sacode a poeira e dê a volta por cima, cara!
Still now I tryied only these T9 games: XMCOTA, RIPOFF, PUNISHER and ACROBATM... and no one was good performances still now. And the time is almost out...
Let's play, Rafael!
