Page 1 of 9
[poll canceled]New rule, using multiple button mapping
Posted: Sat Mar 26, 2005 9:23 am
by The TJT
We are voting on this rule:
2.n) Mapping two or more of the original arcade machine's buttons to a single key or joystick button in MAME is not permitted. Also it is not permitted to use more than one key or button in MAME for the same arcade machine button simultaneously.
This is to get even playing ground, and close as possible arcade experience.
Example1: You map key Q to mame buttons 1 and 2 and 3, you get 3 pushes by pushing only once --- not allowed
Example2: You map keys Q,W,E,R,T,Y to mame button 1 and smash them simultaneously, to get unhuman firing speed ---not allowed
Check out discussion
HERE
This poll runs 6 days, thank you,
TJT
Posted: Sat Mar 26, 2005 9:33 am
Sounds fine - but what about mapping one key to two directions, ie: for easier diagonals. I don't have so much an issue with this, and would be willing to allow that specifically.
It would probably also be a good idea to add the examples to the rule as well, just to make it clearer.
Posted: Sat Mar 26, 2005 9:45 am
by The TJT
mahlemiut wrote:Sounds fine - but what about mapping one key to two directions, ie: for easier diagonals. I don't have so much an issue with this, and would be willing to allow that specifically.
I'll do now another discussion about that. allowing diagonals can be added to this rule later.
My opinion would be that it's not ok to do with atleast fighting games.
Posted: Sat Mar 26, 2005 9:53 am
by Weehawk
I voted "yes".
And I would like to point out that the examples Tommi gives were, in my opinion, always against the rules.
We're just making it more obvious.
Posted: Sat Mar 26, 2005 9:54 am
by SprintGod
The TJT wrote:Example2: You map keys Q,W,E,R,T,Y to mame button 1 and smash them simultaneously, to get unhuman firing speed ---not allowed
Doing that will end up worse than just tapping a single button. You will only ever be able to fire if you release all of the buttons before pressing another one, which will rarely happen without incredibly accurately timed keypresses. That is, of course, if it doesn't completely lock up your keyboard.
It's far, far better to use a single large button and tap it with two fingers.
Posted: Sat Mar 26, 2005 10:08 am
by The TJT
Weehawk wrote:I voted "yes".
Exactly.
by BlackTMH
1. If U wanna real playing buy oryginal arcade with oryginal game .. Have U enough money ?
2. At Mortal Kombat series is imposiible to do some special moves on keyboard without key mapping.. Eg. try to do "slide" at every time .. good luck..
3. If this vote will add this rule then M.A.R.P. will sucks..
Posted: Sat Mar 26, 2005 10:11 am
by The TJT
BlackTMH wrote:1. If U wanna real playing buy oryginal arcade with oryginal game .. Have U enough money ?
Some arcade sticks are not so expensive.
And allowing diagonals is another discussion already.
We are just trying to make a rule here what has been unwritten rule already.
End of discussion.
Posted: Sat Mar 26, 2005 10:21 am
Back when I was using the keyboard with MAME, I never had any need for extra key mapping. If there was a clash, then I found a config that didn't clash.
And I wonder if USB keyboards suffer from clashing...?
Posted: Sat Mar 26, 2005 10:23 am
by Weehawk
Sorry if we're ruining MARP for you.
By the way, what is your username on MARP?
Posted: Sat Mar 26, 2005 10:26 am
by BlackTMH
If isn't expensive, then pleasy, buy one to me
You're setting up new rules cause you are bored and you are willing to show-off how important you are, your new rule won't help anyone, on the contrary it will be unhelpful.
by destructor
The TJT wrote:Some arcade sticks are not so expensive.
Then please buy it for me. I'm poor. And in Poland is impossible to buy arcade stick.
Posted: Sat Mar 26, 2005 10:32 am
I'll swap you an arcade controller for broadband access
Posted: Sat Mar 26, 2005 10:34 am
by destructor
If final vote will be yes then mapping will be disallow in games as Crazy Climber, Assault ... too?
Posted: Sat Mar 26, 2005 10:36 am
by The TJT
Thanks a bunch. I'm so happy to run this poll.
This wasn't my idea to start the conversation about button mapping anyway.
Further posts under this thread will be deleted. Back to playing now.
