TG settings:
So as marp accepts TG settings, it's enough to just put "TG settings" in description. No need for special rule here.1942 Normal 3 20,000 every 80,000 Yes
I think the whole original concept of showing "TG settings" in a description for scores submitted to MARP was where TG staff(well, Mark) would check MARP and search for "TG" in the description to get the replay files for new TG submissions.Weehawk wrote:Why on earth base acceptability at MARP on settings decided upon by TG, completely outside of MARP's influence?
care to list examples? It's possible in many of those cases the track settings can be adjusted to match what factory settings were if the current TG settings are easier.The rule is, in fact, contradictory in cases (and we are discovering more and more of them) where TG settings are more lenient, or "easier" than MAME defaults.
I would like to add that many many times I have seen "TG settings" or "TG" in the description when the gamer did NOT use TG settings at all etc. I have no idea why they put TG in their description....perhaps they think TG refs don't even check the game settings in replays? cmon.***PL*** wrote:marathonable games, it became acceptable to state "TG - 5 men only" but this in turn carried over to other games where there were already WR's in place.
I don't see much wrong with this rule. TG or MAME default. If MAME or TG settings change to easier than before, then that's a problem.h) Recording submissions must be recorded with that particular ROMset's defaults or TG (Twin Galaxies) settings. A recording set at easier or different settings is subject to deletion, especially if it is higher than others at more difficult settings. Recording on TG settings, which are the official arcade game settings, is preferred, and will gain your scores further notice from your fellow players.
Like I wouldn't have enough thinking with other conversations! Geez!PL wrote: Someone had to set the standard and for MARP to boil it all down to 2 options is most acceptable. All references to TG provides a level-set for comparision to arcade scores.
Yes, Rule 2h is a bag of snakes.Zhorik wrote:Ok, if TG settings are allowed, what is the canonical reference source for them? For at least some games, http://cubeman.org/tgts.txt and searching at http://www.twingalaxies.com give different settings for the MAME track.
For example, Bump N Jump is listed at cubeman.org as:
Difficulty Hard, 3 Man Start, 1 Extra at 30K and no more
The twingalaxies database MAME track at http://www.twingalaxies.com/index.aspx? ... 32&vi=7700 lists:
Difficulty Hard, 3 Man Start, Extras every 30K
Jungle Hunt is listed at cubeman.org as:
3 Man Start, Extra at 10K, Finish Bonus = 2X
The twingalaxies database MAME track at http://www.twingalaxies.com/index.aspx? ... 79&vi=7750 lists:
3 Man Start, No Extra, No Finish Bonus
-gastrainga
Both are the two valid sources for TG settings. If there is a discrepency between them, I would use Mark's. Given that Mark originated the list and then later it was folded into TG's website, I'd have to say Mark's is the trusted source. Mark is much more through than the temps hired to post those settings back in 2001. And given TG's continued lax effort in keeping its scores and associated settings up to date, I would be inclined to believe Mark even more so because he concentrated solely on those games and only on the MAME platform. Very focused effort on his part.Zhorik wrote:Ok, if TG settings are allowed, what is the canonical reference source for them? For at least some games, http://cubeman.org/tgts.txt and searching at http://www.twingalaxies.com give different settings for the MAME track.
If the rule was changed, recordings made before the change could be "grandfathered", that is, excused from complying with the new rule, although I do NOT think that this would be the best course of action.It's ludicrous to have people re-record games going back to 1998.
Actually, I would need to check this myself, but if the TG scoreboard is now showing the new, "live" updated MAME scores and settings, then what is on that is the current settings.***PL*** wrote:Both are the two valid sources for TG settings. If there is a discrepency between them, I would use Mark's.
If you think otherwise, send Mark a note for clarification.
