A few settings I'm not sure about, also need to know if they affect playback at marp ?
RDTSC, so this is a Pentium timing thing ? should I enable it when recording ?
Increase thread priority, so is this the same as selecting thread priority through the task manager ? how much does it increase it ?
Direct 3d, I have an average 64mb graphics card, should I enable this option ?
Triple buffering, will this affect recordings ?
M68k core, should I just leave this set as C ?
Rat
Questions about default game options
Re: Questions about default game options
Only necessary if MAME runs better for you when using it. No effect on playback.Rat wrote:A few settings I'm not sure about, also need to know if they affect playback at marp ?
Yes. This will give the MAME process higher or lower priorty for a slice of CPU time. No effect on playback.Rat wrote:Increase thread priority, so is this the same as selecting thread priority through the task manager ? how much does it increase it ?
Only if you really need to. Shouldn't affect playback. Note that this nothing to do with emulating systems with 3D video hardware (PSX, Model 1...)Rat wrote:Direct 3d, I have an average 64mb graphics card, should I enable this option ?
No.Rat wrote:Triple buffering, will this affect recordings ?
Yes. C core is the slowest, but also the most accurate. The speed difference between the 68000 cores is negligible on any reasonably specced system (>~800MHz). This will affect playback for games that use a 68000 (maybe 68010 as well) CPU. WolfMAME stores this and automatically sets it on playback, though.Rat wrote:M68k core, should I just leave this set as C ?
- destructor
