hello everyone, i have a problem with WolfMAME PLus 0.87u1 ,when i try to configure the default controls coins,on screen display,pause,etc,it doesn't save the settings after i leave the game,it keeps the game settings but not the general.
Works fine here. Make sure your cfg folder isn't read-only, and do the same for default.cfg in that folder. If you're desperate, you could always just hand-edit default.cfg in Notepad.
I found it, it's kind of a compatibility problem,i was using the psxpad driver to use my xbox controller, then i changed it to XBCD http://redcl0ud.hostrocket.com/xbcd.html and then it worked fine,just how odd is that!
