d) NVRAM, including the default NVRAM, is prohibited, with the exception of extraordinary circumstances. It's best to delete the NVRAM directory to ensure this doesn't happen. You can also download this file to ensure no nvram is used if you use the DOS Prompt. (usage: record {gamename}). It should be noted that in some games, having hiscore.dat present can affect playback, as can memory cards (memcard\memcard.*), so it would be wise to remove these before recording.Code: Select all
d) The use of nvram files is prohibitied, unless otherwise specified in special rules. If a person thinks a certain game fits into that category, he must contact any of the editors so they can discuss the issue. After the discussion all the editors will vote for or against the idea and present a final decision. All games will be discussed on a case by case basis.
You can also download this file to ensure no nvram is used if you use the commandline. (usage: record {gamename}). It should be noted that in some games, having hiscore.dat present can affect playback, as can memory cards (memcard\memcard.*), so it would be wise to remove these before recording.
The same goes for difference files (diff\*.dif), which contain changes made to a CHD (Compressed Hunk of Data - typically a Hard Drive or CD image). If the corresponding file isn't deleted or moved before recording, the INP is likely to be unplaybackable.It should be noted however that per item 6.b) in the Editors' Rights and Responsibilities, which reads:
b. May edit any regulation rule at any time by a majority vote. However, if the general public agreed to a rule in regulation play at any point, the editors must have a 2/3 vote of all editors in order to change.It should also be noted that per item 3 of the General Voting Procedures which reads:
3. All votes will be passed if it achieves a majority vote of the general public with the exception of a vote going against a standing rule (for example, all games will be one credit in length), then it must be passed by a 2/3 vote of the general public.
