oh nooo!
That makes me a happy confirmer..Don't know how I could pass my time without them (insert ironic smiley here).
Their next task is to beat Weehawks awesome phoenix score at all clones!
edit: After that..they'll submit all Gauntlet clones a score of 10k...shortly after they find out about the 8k trick and resubmit all with 30k!
So does anyone?Zwaxy wrote:Does anyone have a Linux PC and a broadband connection on which they can run a proxy server for me, so I can use it to trick the work firewall into allowing me to edit the MARP site? That would help a lot. PM me if you can help & I'll tell you what you need to install
Linux PC, yes - broadband connection, hell no.The TJT wrote:So does anyone?Zwaxy wrote:Does anyone have a Linux PC and a broadband connection on which they can run a proxy server for me, so I can use it to trick the work firewall into allowing me to edit the MARP site? That would help a lot. PM me if you can help & I'll tell you what you need to install
Huge romz? What huge romz? *hides kinst.chd*The TJT wrote:So how you get your huge romz...![]()
Probably. But I'm sure it'd be a lot easier to be able to tweak something when you're able to access it yourself. That, and programmers are lazy. (Ask seymour)The TJT wrote:Maybe it would be possible for Chris to give you new code and you to ftp it then?
Re: oh nooo!
Ever notice that they seem to be specifically looking for games with lots of clones? Ugh...Chad wrote:the ger* brothers have found the toobin clones, look out when the find the other atari ones!
unconfirmed reports shown on uploads page that mr. shindler pushed my 8th place centipede timed to 9th.
oh , no.
he did get 80 leaderboard points recently
by getting 2nd place on super cobra sega
good work.
still in awe of the vanguard games ,
serious.
skito , he got a whopping 3,000 on space demon !
sometime i will learn to play inferno.
oh , no.
good work.
serious.
It won't get confirmed either.tar wrote:unconfirmed reports shown on uploads page that mr. shindler pushed my 8th place centipede timed to 9th.
He apparently played with sound on, oblivious to the Special Rules.
Also, I note that his inp plays back with sound on (though not to the advertised score), even if one uses the -nosound option on playback. Not sure if this was an intentional change or just another fuck-up inherent in .84
I note that he is already up to 21st place by the old leaderboard's calculations. At his current average of 19.6 points per game and yesterday's rate of 17 submissions per day, he would top BBH in less than four months.tar wrote:he did get 80 leaderboard points recently
Weehawk wrote:Also, I note that his inp plays back with sound on (though not to the advertised score), even if one uses the -nosound option on playback. Not sure if this was an intentional change or just another fuck-up inherent in .84
The Documentation wrote:- added sound/nosound check, the correct option will also be forced on playback
- Gerhard S
- MARP Serf
Re: oh nooo!
yes i found the toobin clones !!!Chad wrote:the ger* brothers have found the toobin clones, look out when the find the other atari ones!
this is a funny game
Gerhard & Crew Pinballs
http://schindler-gerhard.de/
germans are cool, clone hunters are lame. Clone Hunter = people who look for all games in marp with no 1rst palces and put up cheesy scores, usually these are clones or new games.
i.e. http://marp.retrogames.com/index.cgi?mo ... xlines=999
Eventually the "real" players of the parent/clone games upload a better score and bump you down in the leaderboard. Hopefully, you will learn to practice on a game before submiting inps so your score will stay longer/higher/appriciated at marp. Good pinball score though!
- Gerhard S
- MARP Serf
I see that differentlyChad wrote:germans are cool, clone hunters are lame. Clone Hunter = people who look for all games in marp with no 1rst palces and put up cheesy scores, usually these are clones or new games.
it should play everyone each play
so that one has a better overview - whether one knows the play
my goal is - to upload each play with good highscore
I estimate that become heavy - because here a few good player
unfortunately a first place is more worth than 1000 second
but I do not give myself still for a long time struck ---
- Gerhard S
- MARP Serf
thanksChad wrote: Good pinball score though!
i play this pinball only 4 times
here are original pinball-highscore of me
http://www.schindlergerhard.de/High%20S ... cores.html
