How to playback DOS versions without compatible sound card?
Hi,
I'm new to this but have fallen in love with viewing great players.
I wanted to watch some marps for Psychic 5, but since I don't have a sound card that's compatible with the old DOS build that was used for
these recordings, what do I do?
Emph
Emph
Buttermaker
- destructor
I never managed to playback that psychic 5 recording, no matter what settings I tried.. And yes, I tried for weeks
I finally got it to work when I gave it a chance with my mothers old pc, using dos version sound on with windows 98.
Good luck, cause it will not be an easy task (if possible) to get that dos recording to playback as it should.
ps:Please tell me if you manage to get it to playback ok. I would love to watch it again...without having to visit my mother
- destructor
- destructor
Heh. I have Win98 not XP. Wuzel say me that with XP is problem, big problem, probably impossible to playback DOS inps. If you have two discs then you can create DOS system on second disc and boot system from this second disc.
Generally you must enter to DOS mode.
Install DOS drivers from motherboard disc for soundcard (it will be set to soundblaster). This will add one line to autoexec.bat. Cut this line from autoexec.bat and create new .bat file (for example sound.bat) and paste line to this file. Download from net cwsdpmi.exe. Next run sound.bat and cwsdpmi.exe and playback inp with soundblaster card.
You can don't cut "sound line" from autoexec.bat if you want always to run soundcard automatcally. But I have problem in run Win98 if DOS soundcard drivers are run.
Have a look for VDMSound - this program gives SB16 emulation for DOS apps running under Windows NT-based OSes (ie: NT4,2K,XP). I am not entirely sure how compatible it is with XP though.
It should also be noted that DOS apps cannot use VESA video modes either, so make sure VESA support is disabled for DOS MAME under NT 4 or later.
