http://marp.retrogames.com/inp/0/9/e/gt ... wolf79.zip
- Did not read the special rules.
- Did not test his recording before uploading.
Punishment is finally in order.
indyheat by Caseh
Buttermaker
haven't tried it yet but will. *might* be working for you caseh with an nvram file which would be another nono, but maybe someone else besides you is wrong in this case.
hey didn't actually see that avg mph score before, maybe we can use that as a 76 tie breaker ('you see good in bad, i like that!')
then it's proly the sound issue if it's not working for someone else, recording with no sound has been required for playingback for others, since this game has timing issues with the sound emulation and messes up if you use different hardware, unless they fixed it, need to try it, will tonight.
i think putting avg speed as a tie breaker is a no brainer here, i'll check other recordings to see if avg speed can distinguish the players, if so i'll change the scoring to go pts*1000 + avgSpeed. so your score would be 76119, but i have a feeling eveyone gets 119, but we'll see.
yeah this recording is a way no go, need 3rd to zero, (if caseh said he could'nt get it to playback you'd be the third... but i'll give him the benefit of the doubt and see if someone else can't play it back just incase it's a blinds thing), you sure you didn't take that screen shot during the game, anyways, it looks like the avg speed and top speed reported there are on a per race basis, so we'd have to add them up for all races to make them an adequate tie breaker, certainly posible but tedious.
- Mr. Kelly R. Flewin
- MARP Knight
Chad wrote:yeah this recording is a way no go, need 3rd to zero, (if caseh said he could'nt get it to playback you'd be the third... but i'll give him the benefit of the doubt and see if someone else can't play it back just incase it's a blinds thing), you sure you didn't take that screen shot during the game, anyways, it looks like the avg speed and top speed reported there are on a per race basis, so we'd have to add them up for all races to make them an adequate tie breaker, certainly posible but tedious.
Works for 2 races then derails faster then Amtrack. Both = 20 points.. didn't look at the speed though ^^;;
Kelly
