batridrk
batridrk
Kelly's input is out of synch from the start and is not recorded with 0.62 or earlier. (Or is that bug fixed in 0.76?)
-Abbe
- Mr. Kelly R. Flewin
- MARP Knight
Re: batridrk
Considering the score above was recorded with Wolfmame Plus 0.71 and confirmed!, I had figured someone merely had forgotten to remove that rule and it worked fine. I even got my playback to work without a problem as well. No problem to go scouting an older version out to fix this though. It would be my fault for assuming, though was not my old recording fine?Abbe wrote:Kelly's input is out of synch from the start and is not recorded with 0.62 or earlier. (Or is that bug fixed in 0.76?)
Kelly
Re: batridrk
Mr. Kelly R. Flewin wrote:Considering the score above was recorded with Wolfmame Plus 0.71 and confirmed!, I had figured someone merely had forgotten to remove that rule and it worked fine. I even got my playback to work without a problem as well. No problem to go scouting an older version out to fix this though. It would be my fault for assuming, though was not my old recording fine?Abbe wrote:Kelly's input is out of synch from the start and is not recorded with 0.62 or earlier. (Or is that bug fixed in 0.76?)
Kelly
Rule requires .62 or earlier, but game was introduced in .68.
"Catch 22, so 23 skiddooo...."
Buttermaker
From #marp log:Buttermaker wrote:And after you renamed the .inp I guess.Weehawk wrote:Plays correctly for me after I set "m68k_c_core" to "0" in the ini file.
<Buttermaker> filenames like that get changed to ******.inp
- MARP Knight
