Space Zap (diabolik)
http://marp.retrogames.com/inp/a/6/d/sj ... mame31.zip
can anyone get this to playback?
Incredible!
Phenominal!
Outstanding!
**diabolical**
-considering evil angela's 133000.
Incredible!
Phenominal!
Outstanding!
**diabolical**
evil_angela
- Button Masher
Also add a special rule that at least that version should be used.
...although nowadays I think any submissions using a version older than 0.36 shouldn't be accepted anyway...and for 0.36 and 0.37 only in special cases like the Sega games.
ie. if a game works properly with versions 0.70 and later of MAME, or 0.60 and later, then no way someone should be going all the way back to 0.37 or older.
When you get to those older versions many games don't play quite the same way or the default dip switch settings aren't the same as they are now etc.
I wonder how many other scores here that are from 1998 using really old versions of MAME haven't been beaten simply because the game plays correctly in later versions making it impossible to beat those old scores.
links would have been helpfull but i manage to find them :) and verify the versions that should be used.
I wonder who else actually played this game in the arcades, i doubt any of the 300k scorers did or they would have mentioned something. The controls for the space zap i played were really cool, no joystick all buttons, and it was sort of a mini cabinent somewhere between a standup and a table. All scores will reflect 3 ships since that is the current default.
However i have a playabck problem with this one, only gets 30k.
http://marp.retrogames.com/inp/f/6/e/pm ... mame61.zip
No worries from me.........
I had no idea what this game played like as I never saw it in the arcades.
Will try it on a later release to see what the difference is - assuming this game will run at full speed on a crusty old K6II-300....
Patwos.
PS: Some of us have to use Mame035 or 036 in order to get full speed on games since we have older hardware - part of the reason I'm not participating much at Marp currently until I can afford, or more appropriately justify, an upgrade that will allow these later versions of Mame to run at a decent speed.
Patwos.
- AL
re....
Well Brian , at least you have the Rugby WC to occupy your time....
I'm working shifts , so I miss the live games . And watching the highlights isn't the same....especially when you already know the result
Cheers ,
p.s Go on the Boys in Green !!
Cheers ,
- Francois Daniel
Same here. Plays back to 31250.Chad wrote: However i have a playabck problem with this one, only gets 30k.
http://marp.retrogames.com/inp/5/2/c/wc ... _win76.zip
No playback / Used win 75
DRN's 194000 plays on wolf 73
Plays back fine on Win 0.76!> http://marp.retrogames.com/inp/5/2/c/wc ... _win76.zip
Kranser.
