In my record had following message:
How about this? Wolfmame32 plus, Disable M68000 C Core [three loops of inactivity, playback ends without a game being started. Yes, I did use the ASM 68k core -br]
the ASM 68k core = M68000 C Core?
If ENABLE the M68000 C Core, my inp will inactively playback.
And my recorder is Wolfmame"32" plus 071u2(GUI).
One or the other has to be used, the ASM 68k core being faster, but less accurate. And there is a message in the console that says that you did use it. I did use the -nom68k_c_core switch, so I'm not sure what is going on, but I will try it again.
