ANNOUNCEMENT : START OF KNOCKOUT TOURNAMENT 3 (k3)
K3 is starting !!
Version used will be alphamame67
The format of k3 will be mostly the same than k2
(I will update a page very soon)
First round will be very easy : it's just a registering round to the tournament ... all players reaching 100 on the game ULTENNIS (using actual Marp scoring) will be qualified for next round ; it means just win a match
I've chosen this game for 2 reasons :
1-there is no entry on it (except mine) and as this is a quite good tennis game, I think it needs to be discovered
2-this game could occure some ties but this is not important for this round (only reaching 100 is the aim, but results will be used for ranking seeds later ... so you can to finish the game it will be better for you)
The following will depend on how many players have registered by passing rd 1 ;
for example if we have 50 players qualified, then the top 32 on next game will be qualified, after top16 ... etc
When only 8 players will remain, we will do quarter-semi-final ; ranking seeds in quarter will be defined by previous results on previous rounds
Start of k3 :
today ; just enter a 100+ score on Ultennis using the entry "k3-rd1" (k3 round 1) to be qualified for rd 2
End of round 1 : saturday 24 May at 23:59 GMT (Marp time)
Good luck to all !!
More infos :
FAQ : can we press ESC after 1st win ?
yes of course, you have still 100 and are qualified
Please check your input before uploading, some of you had some problems ; if needed you can use alphamame66, there is no playback problem with this one
I wasn't aware there was yet a alpha68 ; of course you can also use it if playback is ok
it looks like I'll be sitting this tournament out, fskp 11 on Ultimate Tennis still only gives me 80% speed :( :( :(
oh well.
Submit a 100 : it's just a registration round ; 80% can be allowed for this round
Gmitra
Post by Gmitra »
i found alphame searching the boards, is there a direct link for it
on marp site? It would be easier to find the version one wants for
this or any other competition
Using the 'get MAME' link should work.
But yes, I really should make up a page for it at some point.
Luja
Post by Luja »
Hi!
I´m totally new to the competitions (knockouts, tournaments...)
My question is the following: (always with questions!! :) ).
The points in the leadership table are affected by the inp of the tournament?
Which are the efects of those tournaments in the leader board?
All the rounds affect the points of the leader board? None?
Thx
Zwaxy has made script so that all entries with tournament prefixes (t6-, k3- ...) are not counted in the general leaderboard
Concerning links to versions, I think Barry should add last alpha bersions to the "old versions" page you can get in the upper banner menu
Phil, all previous like o1- etc. all had "0 pts" for the leaderboard pts associated with the scores.
The k3- submitted scores are having leaderboard pts assigned to them and appears to count toward their total.
You can see this by easily looking at the uploads which has a few k3- entries already.
A couple have even submitted the same inp for the game itself for the leaderboard pts.
I thought an inp file is only allowed to be applied to one thing. Even when/if the k3 scores don't yield any leaderboard pts they shouldn't be allowed to use the exact same inp file for both k3 and regular score submission IMHO.
Don't worry ; just an omission by Zwaxy : he will fix that soon I'm sure
Gmitra
Post by Gmitra »
i tryed alphamame32-066-3 alphamame32-067-1 alphamae-64-3
and i can never playback my inps , always goes out of sync
any tips ? or maybe a version that wil work cause i just cant download
every alphamame there is and try .
thanx
Gmitra
Post by Gmitra »
thanx
AlphaMAME 0.67-2 & AlphaMAME 0.68 have worked for me.
Remember that MAME now auto-creates the NVRAM folder. Setting nvram_directory to NUL in mame.ini (or Options->Directories... in MAME32) will fix this.
