0.68 is out!
Posted: Fri May 16, 2003 5:28 am
Haze rules!
0.68.
Note, this Release was put together by David Haywood, some of it is
untested but most of seems to work.
General Source Changes
SHA1 hash support, including various new command line options [Farfetch'd]
Mame Blitter Generation Code [Phil Stroffolino]
Basic Direct3D blitting support [Leon van Rooij]
You need DirectX7 headers and libs to compile it, I'm using the set from
http://caesar.logiqx.com/html/tools/com ... ingw.shtml which has the
original MS headers (the same set is used for Allegro and FB Alpha) and
I've made a minor update to the ddraw code so that it compiles with this
set of headers (VC++ should still be fine as well).
The code manually imports the DirectDrawCreateEx() function so MAME
compiled with d3d support will (or rather should, I've not actually tested
that yet) still run on PC's with older versions of DirectX. It should work
with pretty much any 3D hardware (except perhaps older Voodoo-based cards),
and the speed should be similar to the DirectDraw blit (a bit faster for
some older cards).
-direct3d or -d3d: use Direct3D (default is off, overrides -dd);
-filter or -flt: use bi-linear filtering (default is on);
-texture_management: use DirectX texture management (default is off, but
some 3D cards need this (however, there's a small-ish speed-penalty)).
Various Konami Related Fixes and Improvements [Acho A. Tang, R. Belmont]
Various System 32 Updates (Priority, SVF Pitch etc.) [Acho A. Tang, Jason Lo, David Haywood]
Sound in Macross Plus & Quiz Bisyoujo Senshi Sailor Moon [Bryan McPhail]
Fixes for Crashes introduced in last version
+ plenty of other things I just don't have time to list.
New games supported:
Chack'n Pop [BUT]
Salamander 2 [Acho A. Tang, R. Belmont]
Tokimeki Memorial Taisen Puzzle-dama [Acho A. Tang, R. Belmont]
Dragoon Might [Acho A. Tang, R. Belmont]
Koi Koi Shimasyo 2 - Super Real Hanafuda [Luca Elia]
Vasara []
Vasara 2 []
Billiard Academy Real Break [Luca Elia]
Cannonball [Jarek Burczynski]
Kick Start Wheelie King [Tomasz Slanina]
Truco-Tron [Ernesto Corvi]
(Super) Ground Effects [David Graves, Bryan McPhail]
Horizon [smf, David Haywood]
Fire Battle [Martin Pugh]
Rapid Hero [David Haywood]
Zero Point 2 [Luca Elia]
Idol Janshi Su-Chi-Pie 2 [David Haywood]
Quiz Ghost Hunter [Olivier Galibert]
Tokoro San no MahMahjan [Olivier Galibert]
Tokoro San no MahMahjan 2 [Olivier Galibert]
Quiz Mekiromeki Story [Olivier Galibert]
Straight Flush [Tomasz Slanina]
SD Gundam Neo Battling [Luca Elia]
Fantasy Land [Luca Elia]
Galaxy Gunners [Luca Elia]
Metal Soldier Isaac II [Angelo Salese]
Progress [David Haywood]
Birdie King 3 [Angelo Salese]
Dark Tower [Bryan McPhail, David Haywood]
Tricky Doc [Reip, David Haywood]
Tournament Table [Stefan Jokisch]
Eggor [Tomasz Slanina]
Rock Climber [Tomasz Slanina]
Kung-Fu Taikun [Tomasz Slanina]
Metal Clash [Luca Elia]
Head Panic
Puckman Pockimon [Luca Elia]
Operation Wolf 3 [David Graves, Bryan McPhail]
Sky Army [Ryan Holtz]
Super Doubles Tennis [Bryan McPhail]
Egg Venture [Aaron Giles]
Lethal Justice [Aaron Giles]
Area 51 / Maximum Force Duo [Aaron Giles]
Prebillian [Tomasz Slanina]
Bwings [Acho A. Tang]
Zaviga [Acho A. Tang]
Wall Crash [Jarek Burczynski]
Mighty Pang [Razoola]
J-League Soccer V-Shoot [Phil Stroffolino]
Rotary Fighter [Barry Rodewald]
The Deep / Run Deep [Luca Elia]
New clones supported
Lethal Enforcers 2 (USA) [Brian Troha]
Violent Storm (Europe) [David Haywood]
Mello Yello Q*Bert [David Haywood]
Big Bang (clone of Thunder Dragon 2) [David Haywood]
Vandyke (Jaleco) [David Haywood]
BlockBuster (clone of Mr Jong) [David Haywood]
Catsbee (clone of Galaga) [David Haywood]
Croquis (clone of Logic Pro) [David Haywood]
Super Pinball Action (US) [David Haywood]
Pollux (set 2) [David Haywood]
Vautour (clone of Phoenix) [Chris Hardy]
Moon Alien (clone of Galaxian) [David Haywood]
Country Club (clone of Fighting Golf) [Tomasz Slanina]
DoDonPachi (International Version) [Brian Troha]
Batrider (Korea) [Brian Troha]
Vs Block Breaker (clone of sarukani) [David Haywood]
Ring Fighter (clone of Vs. Gong Fight) [David Haywood]
Space Panic (various alt sets) [Zsolt]
Piranha (GL sets) [Dave Widel]
Hydra (prototype set 2) [Aaron Giles]
Millpac (clone of centipede) [Chris Hardy]
Some Cps1 Clones [Razoola]
Bang Bead (Release Version) [Various]
Terminator 2 (LA1) [Brian Troha]
Various NeoGeo Clones [Razoola]
New TESTDRIVERS in source
Shougi [Jarek Burczynski, Tomasz Slanina]
Shougi 2 [Jarek Burczynski, Tomasz Slanina]
Konami's Open Golf Championship [Acho A. Tang, R. Belmont]
F1 Grand Prix Star 2 [Luca Elia]
Ultra Weapon X [Luca Elia]
Joryuu Syougi Kyoushitsu [Luca Elia]
Hot Rod [Olivier Galibert]
Bonanza Bros [Olivier Galibert]
Quiz Rouka Ni Tattenasai [Olivier Galibert]
Thunder Strike
Hot Smash [Tomasz Slanina]
Raiden 2 [Bryan McPhail]
Grand Tour [David Haywood]
Great Wall
China Dragon
Space Bugger [David Haywood]
Main Event (SNK) [David Haywood]
0.68.
some older cards).
Chack'n Pop [BUT]
Vasara []
Vasara 2 []
Head Panic
Thunder Strike
Great Wall
China Dragon
