Uploading AlphaMAME32
Posted: Tue Apr 22, 2003 2:55 am
by artz
I used version AlphaMAME32-067-1 to record a game and was wondering if I need to select "AlphaMAME 0.67 (TG)" in the version of MAME used category. I've uploaded many scores before, but I don't see a seperate selection for Mame32. If not, will it be in the list soon. There is a note that says not to upload a recording for a version of mame that is not on the list.
Thank you.
Re: Uploading AlphaMAME32
Posted: Tue Apr 22, 2003 3:10 am
by Mr. Kelly R. Flewin
artz wrote:I used version AlphaMAME32-067-1 to record a game and was wondering if I need to select "AlphaMAME 0.67 (TG)" in the version of MAME used category. I've uploaded many scores before, but I don't see a seperate selection for Mame32. If not, will it be in the list soon. There is a note that says not to upload a recording for a version of mame that is not on the list.
Thank you.
There's 2 seperate listings, one lists Alphamame 0.67 and the other is Dos Alphamame 0.67.... the first is the Win and Win32 versions .. the second is dos only... which does make a difference. I don't know if there's compatibility issues between like... 67.1 and 67.2, but in case there is, I mention which revision I am using in my descriptions to aid confirmers.
So basically, you will need to select the first Alphamame option to upload your score. ^^
Kelly
Posted: Tue Apr 22, 2003 3:28 am
by Skyline
If you're extremely paranoid about it, just add "AlphaMAME32 0.67.1" to the .inp description.
Posted: Tue Apr 22, 2003 4:34 am
There is no difference between MAME and MAME32 other than the fact that one is commandline driven, and the other is GUI driven. I see no point in adding another version listing for a version that is practically identical to another. The DOS and Linux versions are pretty much compatible as it is.
Posted: Tue Apr 22, 2003 8:27 am
by artz
Thanks for your quick response.
Posted: Tue Apr 22, 2003 1:13 pm
by artz
Skyline wrote:If you're extremely paranoid about it, just add "AlphaMAME32 0.67.1" to the .inp description.
Thanks Skyline, I took your advice. And yes, I'm always paranoid.
