http://marp.retrogames.com/inp/kys_pooy ... _mac36.zip
--edit addition---
According to the below this inp is compatible with mame32-v36 so watch it to see exactly what is going on. My description below although detailed just doesn't give you an idea of just how bad this leech is until you see it.
---end addition-----
It's a macmame inp so unless compatible with PC mame you all won't be able to watch this....so let me try and describe as best I can what he does in this game. I think this following technique is very similar to techniques for many games that MARP has banned. I think this technique should be banned also. I'll turn this into a poll if necessary after a little feedback from others here.
90+% of his score is by using a leeching technique that requires just a little bit of skill to setup and once setup requires no skill at all really to leeching for a long time.
He did a little leeching in rounds 1 and 2 but the big leech came in round 3. Shoot all but 2 wolves...now let them pass a couple times so 4 wolves fill up on the ladder trying to reach your family of pigs.
Ok, once you do this only 1 of the 2 remaining wolves will be falling down at a time. Oddly that wolf doesn't climb up the ladder to "kill" you...but just returns to the top...over and over and over forever...for 10-15 passes the wolf fires 1 shot at you...where you can be sitting in 1 spot between the wolves on the ladder. You can fairly easily shoot his shot at you...after about 10-15 times, where he falls down changes position and the wolf no longer fires at you. There is now absolutely no threat of you dying in this round.
Ok, here is the leech...once you have that setup...not all that hard to do... a pink wolf at the top is dropping strawberries which you can shoot for 200 points each. The supply of those strawberries is endless. All you have to do is be careful not to shoot down that falling wolf but shoot just the strawberries.
This player in round 3 amassed about 700k from doing this in just round 3. He then accidentally shot that wolf so that round ended. He then played round 4 normally...losing a couple lives....then played round 5 losing a few lives however once again setup the scenario of shooting all but 2 wolves and letting the ladder fillup...then leeching points off shooting the strawberries.
He screwed up again shooting the wolf but then set it up again in round 7 and stopped when he reached exactly 1 million points.
This playing technique is as bad as a degree of leeching as any game has. The total game time was about 2 hours to 2 hours, 15 minutes..of which about 10-15 minutes was actually playing the game while the rest of the time was sitting in that spot leeching points off the strawberries.
I have not watched either of the PC inps to see if they do something like this.
However, I think this leeching is very cheap and not really requiring much skill to setup and should be banned.
If it would help others I can take a few screenshots or even perhaps try and make a 5-15 second movie showing the leech...which you then could just imagine that going on for 2 hours. Just let me know.
You get 200 points per strawberry. He likely got around 900k of his score from strawberries. That would be 4,500 strawberries!
So whatcha think?
