Ti.jp question!
Luja
Ti.jp question!
Post by Luja »
Or another to known this...
How do you defeat the last boss in Golden Axe the Revenge of Death's Adder? (the boss that appears 3 times)
I saw your inp and you use a trick to defeat him (in the matter that he has no attack). Can you explain me to probe it?
Thx
Ti
Post by Ti »
Nice to meet you Luja.
I can only sometimes do that.
I don't know exactly how to do that.
But I can defeat Death Adder without that trick because he is not too strong.
Shall I show it in inp of US version?
Luja
Post by Luja »
Hi Ti!
Finally I defeat Death Adder without tricks. (at last! ).
I have interesting in the trick, because the times that I arrived at the final stage, I don´t reproduce it. With your answer is suficient, I only want to known if the trick can be do all times (that I believe not; sure not :? ) or only sometimes.
Thanks for your answer.
PD. What game are you now trying to do the first place? :wink:
Ti
Post by Ti »
Congratulations Luja!:D
Let's play GA2 more for the higher score!
There are three knacks of the high score.
1 Drop enemies to the hole.
2 Pick up all items. (Don't forget apples. )
3 Don't die.(It is needless to write.)
My next recording is Altered Beast again ,maybe. 8)
Luja
Post by Luja »
Thx.
Thx again for your tricks. I don´t understand something...
* Droping enemies to the hole gives you more points???? 8O
Are you exactly speaking about the 4th stage: the mountains?
Droping enemies gives you more points?? I believed that killing enemies
instead of droping to the hole gives you more points!!!
* What exactly is "apple"? The fruits that appears on the tree? I saw your inp and you have collect 5 fruits on the 2th stage (one hidden; your inp was usefull to me for finding this "hidden" fruit)
Regards.
PD. I've seen your last inp. Nice record. :wink:
Which's your country? Japan?
RE
Post by QRS »
I think it is the same as Golden axe 1. Dropping enemies gives you more points in the end than just killing them. I may be wrong but I think that´s the case. There are a lot of factors that decides the points beside that too.
I think Hisa knows more of this that I do :)
Cheers
Luja
Hisa, Tj, QRS...
Post by Luja »
Wow. That's interesting.
How is the amount of points for dropping an enemie to the hole?
How is the amount of points for killing the same enemie?
THX
Ti
Post by Ti »
I'm sorry for my poor English.
"HOLE" means the river, the sea, and the precipice, etc.
"APPLE" is a product of magic that TRIX use.
I don't know the amount of points for dropping an enemie to the hole.
But probably, my inp reached the limits of score on GA2(J).
Look at my inp carefully.
Good luck. :D
Luja
Post by Luja »
My English is poor, too. :wink:
Now I understand your message completely. I never can imagine the trick of the "hole"!!!! Wow!!!
Is there another interesting trick? For example, killing the bosses with a special movement gives you more points? I think no.
I do a test to see the difference of points. And the result is:
* Kill an enemy: 1 point.
* Drop an enemy to a hole: 6 points.
Regards.
your english is great guys (except for the "Hole" thing :lol:), i am new to golden axe 2, only played golden axe 1. One thing i also did notice Ti do is unleash the purple beak things from their coral. I'm guessing that gives you an extra point or so. Luja never does it but does that mean it doesn't give him points? just a observation.
Ti
Post by Ti »
thank you for seeing my inp.
the scoring system of GA2 is simple.
that action doesn't give me an extra point.
Novice
The greatest info supplyer
Re: RE
Post by Novice »
QRS wrote:I think it is the same as Golden axe 1. Dropping enemies gives you more points in the end than just killing them. I may be wrong but I think that´s the case. There are a lot of factors that decides the points beside that too.
Cheers
similar to Golden Axe 1.
viewtopic.php?t=7678
you make simultaneous equation, problem will be solved simply.
DEFence CONdition
WAR 1<< >>7 PEACE
Luja
Golden Axe Revenge of Death Ader (scoring)
Post by Luja »
Hi Chad! (welcome to the Golden Axe 2 :wink: )
The scoring in Golden Axe 2 is more simply that Golden Axe 1:
* Kill an enemie: 1 point.
* Drop an enemie to an abyss (my "hole" :) ): 6 points
* Drop an enemie to the water: 2 points
( for example in the first stage, in the harbour stage)
* Drop an enemie from a mushroom: 2 points
(stage 2; the trees...)
* Bosses: variable points.
* Death Adder (first and second): 30 points each one
* Death Adder (last): 70 points.
* Potions or food: 1 points each one.
* Loose 1 life: -10 points.
The other things don´t give your more points.
It's equal to use more time, magic, or damage.
Good luck!
