AlphaMame Blocking Bonus
In order to promote Alphamame and make it even more valuable to the community [And to recognize the willingness for players to play on a fair level], the editors have decided to bonus alphamame submisions.
The vote is here because everyone should have a say in how it is to be done. For now, we can't think of a precise way to award more bonus leaderboard points to different mame versions, because the math just gets too complicated. But it is possible (and most importantly easy for zwaxy) to give alphamame recordings a stronger stature and to award a player for using a mame that is impossible to cheat with the currently known cheating methods (slowdowns, rerecording, pausing).
If this rule passes by 2/3rds of the voters, any Alphamame recording (61 and higher), can ONLY be beaten at marp with another Alphamame recording. In other words, when someone uses regular (insecure) mame to get a higher score than alphamame recording's score and uploads that score after 3-3-2003, it will not be allowed at submit time. A few exeptions: xmame/macmame recordings would still be allowed to beat alphamame recordings because there is no alphamame for these platforms yet. When AlphaXmame and alphaMacMame come out, they will also block regular xmame and macmame recordings when submited.
Passing this vote will NOT force newbies to use alphamame. But if newbies want to beat alphamame scores already submited by veterans (who already know alphamame is a way to put the most pride into recordings), the newbies will have to learn and use it.
So go n' vote.
So go n' vote.
If this vote is passed, is there anyway BR could code an alphamame for version 36 or maybe some other older versions? I ask this because some games like hangon don't work properly in the later versions but work fine in 36. Smashtv also won't record with sound in the newer versions but works fine with sound in 36. There are numerous other examples of games that work better in older versions of mame. I would hate to have to start playing certain games with -nosound just to submit inps to marp.
Re: AlphaMame Blocking Bonus
Ok, thx for realizing that. I gasped when I read what the poll was at first....cuz that would have meant the end of MARP for me..until I saw this exception. However, one angle to consider is those on PCs that run Windows but also have Linux installed and want to actually cheat by fudging inp recordings etc. to get high scores or pause or change controller options during the game would just play using xmame instead and still do all of that. Given they go to such trouble to hack up an inp file it's not that much trouble for them to play in xmame instead.Chad wrote:A few exeptions: xmame/macmame recordings would still be allowed to beat alphamame recordings because there is no alphamame for these platforms yet. When AlphaXmame and alphaMacMame come out, they will also block regular xmame and macmame recordings when submited.
On another note, I think this will only work if the mame version list in the submit page is changed so it includes more than just that one mac version of mac36. As you have seen with my submissions macmame60 is current and if i know the inp is cross-platform compatible I select mame60 from that menu so confirmers that like confirming with that version will see it and confirm it. I still include macmame60 in the description though.
If this above was passed, I could still note the inp is cross-platform compatible but would like to be able to select mac60. To select mac36 is deceiving. We also would need other versions like mac58 noted cuz there are a handful of games like Karnov that play fine in 58 but don't in 60.
Version 65 is being worked on but hard to say when the person that develops macmame will complete that....could be weeks...or months...or never if he loses interest.
Without writting it out, I would like to echo LN2's words. I don't have access to (a stable) Windows at work (where I do get some time to play). I'd hate to get a difficult high score there & then have to come home & replay the whole just to upload without penalties.
Roll on AlphaXMAME / AlphaMacMAME! Though I realise that AlphaXMAME will be a real pain to get to work as distribution compatible, let alone GLIBC version compatible!
An X11 version would certainly be possible for me to do, although at the moment, it would be binary only, so compatibility would be limited to 80x86 systems, and maybe only certain distros too. Producing a library is certainly a possibility, like what I did for Skito and Ben Jos. This would then give compatibility to Unix/Linux/MacOS X. At least when XMAME fixes INP recording and playback, that is.
If you compile it with -static, xmame.x11 will work anywhere with X (maybe with the exception of macosx :). although not with any hardware dependent makefile switches flipped. A true alphaMacmame is the problem since we have no major mac developers in the editor realm. But your macmame build dude is welomce to include the public alphamame source features, writes his own encryption and if we can't hack it, we'll accept it as a secure mame here at this level.
It's more likely we'll see an alphaXmame66 more than we'll see a alphamame36 but it's all up to barry. So i think recording with out sound might be the only thing to do, but mame usually gets fixed so be patient and record when new mame's working right.
oh yeah the motorolla thing :) i guess there's always the cross compiling nightmare. and NO distributing the library won't be possible. me and ben jos got the decrypting libraries (to create the inp analyzing tools) which is ok to distribute. But the encryption library (required to build an alpha mame) wouldn't be ok to distribute. Because then anyone could encrypt regular mame inps into alphamame inps.
However, the interface to the encryption library would be able to be distributed so you could release the bare alphamame source (with a call/ref to the encryption/decryption routines to be linked securly) and then the mac devs could write their own encryption/decryption routines and link with alphamame source.
Before voting...
I want to known some things.
* I think that the win version of alphamame, like Mame32, uses the registry to store his information. So, this will be make troubles?
I say troubles about installing more than one win version in the computer.
For example, I want to keep in my computer Mame32 and Alphamame32 (if exist).
* Has alphamame32 the same features of Mame32?
* Will be troubles if I install in my computer alphamamew (the windows version withouth the gui) and mame32?
* Which versions of alphamame exists? Where can i download them? I follow the links of versions but the existing ones are old!!!
* How much time frequenly differs between the release of the standards mame, mamew and the alphamame versions? I say this, because the games added to a new version of mame, in this period can be submitted with great scores (because there aren´t alphamame recordings yet) or with cheats in them...
Regards
Regards
Re: Before voting...
Yes. AlphaMAME32 works the same as MAME32, with the extra features of the other AlphaMAME versions too. Each verison is based on the official source releases of each version.Luja wrote:I want to known some things.
Shouldn't be.Luja wrote:* Will be troubles if I install in my computer alphamamew (the windows version withouth the gui) and mame32?
Each version I release is posted in the General forum. Latest is 0.65.1.Luja wrote:* Which versions of alphamame exists? Where can i download them? I follow the links of versions but the existing ones are old!!!
Hopefully no more than a week. Depends on time. Weekends are usually best for me.Luja wrote:* How much time frequenly differs between the release of the standards mame, mamew and the alphamame versions? I say this, because the games added to a new version of mame, in this period can be submitted with great scores (because there aren´t alphamame recordings yet) or with cheats in them...
Last question (mahlemiut...)
I'm almost sure to vote yes (although the pause problem mentions by Phil Lamat).
Do alphamame32 use the same registry keys than mame32?
It will be perfect to use another (for example in Software....freeware\aplhamame32 intead Software....freeware\mame32), so I can keep the two versions (one for mame32 and another for alphamame32, using the same rom,dat... files)
I believe that the secret feature that is improving mame32 team is "not using the registry for saving configuration"....
Thx for your quick replies.
Re: Last question (mahlemiut...)
I don't change anything related to it, so I'd figure it would use the same registry keys as regular MAME32.Luja wrote:Do alphamame32 use the same registry keys than mame32?
