Novice!!
Posted: Thu Feb 13, 2003 12:04 pm
by INNUENDO
Please, tell me what´s the GAMEST SCORE on PUZZLE BOBBLE 1 and 3. Thank you.
Posted: Thu Feb 13, 2003 1:28 pm
I'm no novice, more like a beginner, but from a possibly old gamest record file:
- PUZZLE BOBBLE 62,323,720
PUZZLE BOBBLE 2 501,955,860
PUZZLE BOBBLE 2 X 535,894,930 X MODE
PUZZLE BOBBLE 3 FUTSUU MODE 749,470,040
PUZZLE BOBBLE 3 2.5 MODE 838,443,980
PUZZLE BOBBLE 4 ???PUZZLE 533,268,370
PUZZLE BOBBLE 4 ?? 70,654,090
Posted: Fri Feb 14, 2003 7:05 am
by INNUENDO
thank you, Chad.
WOOOWW. And I thought the 500 million of HISA was the maximum of points that a player can do on PBOBBLE3. and how the player can do 62 million on PBOBBLE???????????? aaaaaaaaaaaaaaaarrrrgghhhhhh!
Posted: Fri Feb 14, 2003 1:37 pm
by Phil Lamat
62 millions on pbobble is possible, but with level 1 or 2 or 3 (default for all neogeo is actually level 4 on Marp) : then you have more time before the roof fall on your head, and you can make more 1.4 million combos
Posted: Sun Feb 16, 2003 8:12 am
by GHEMANT
1 june I will compile a new release of GAMEST RECORD LIST
include 2002/2003 record by aracadia
Posted: Sun Feb 16, 2003 9:29 am
by Novice
DEFCON=5
Phil Lamat wrote:62 millions on pbobble is possible, but with level 1 or 2 or 3 (default for all neogeo is actually level 4 on Marp) : then you have more time before the roof fall on your head, and you can make more 1.4 million combos
62 million was played with LEVEL 4.(factory default)
There is 57millon points replay with LEVEL4 in my hand.
It certainly lost several 1310720points combo.
do you want to see?
Re: Puzzle Bobble inp
Posted: Sun Feb 16, 2003 10:09 am
by LordGaz
Yes I would be interested in seeing a 57M inp for a windows version of MAME (not DOS, XP has problems with DOS MAME). There used to be playback problems for this game and DOS mame34 was the only version that created valid inp and even that was a bit hit and miss. Do more recent MAME32 versions play it back ok, I haven't tried?
Please come to #marp on irc.lazynet.org and /dcc me or post a link.
Gaz
Posted: Sun Feb 16, 2003 12:15 pm
by Novice
DEFCON= 5
Then down load it from here.
http://www.interq.or.jp/black/sekkey/re ... lay-p.html
nvran needed m37b9i686 version.
tell me detail score after you see it.
Posted: Sun Feb 16, 2003 4:17 pm
by LordGaz
Thanks, it replays back to 2673280 round 3
even with the nvram and the correct mame version. He gets two 1310720 combos on round 1, round 2 is over on the first ball and round 3 is where it finishes. I tried for three hours with different nvrams and machine configurations and it will not play back in its entirety
Gaz
Posted: Mon Feb 17, 2003 11:42 am
by Phil Lamat
Same for me
But if you record with any version since m60, it will playback ok (playback problems with neogeo games have been fixed in m60, especially in dos)
Posted: Wed Feb 19, 2003 4:39 pm
by INNUENDO
Hisa, it´s possible for you, record again using a recent emulator? Please?
