891700 confirmed, played it back twice one with fs0 no throttling, another time iwth fs0 with throttling. i'll bet the earlier version of mame took a NON RTC seed or a seed based on user inp (so when it playsback it can regereate the dangseed. huuh huh, he sayd seeed, huh huh.)
I was just hoping for a yes or no answer, preferably yes. thanks a lot, this is good news. maybe turning sound on affects a random seed somehow. Now to just get a game where they give me all 4 random bosses on a recording with sound off...
Chad wrote:kale, can you mail me your patch you sent to mamedev? i'll bet if it is forces all neogeo mame games to use a constant seed they won't allow it, unless it's connected to a user option to turn off or on.
Note A: There is usually a lateness between submitions and the news being added in the WIP(i.e. Block Gal driver was submitted on the 5th april 2002 and being noted on the 9th),so I'm still waiting for that being noted...
Note B: The submitted inp has already an user option;if you say:"use record or playback option,set time to zero,otherwise set time as the current time of the PC".Also,I didn't removed the clock when you use inps.The clock still goes forward when you play,so the seed is safe...
thanks kale, code looks good dont need an option if it's only going when recording or playing back. although a patch "diff" of the source might be more apropriate than a full source code c file.
If you use a diff for a submission ,it's afaik harder that will be added into next MAME,especially if another file (with different code changes)was submitted before that by somebody else...
so then what happens when two people submit two neogeo.c files, you think the mame team wants to try and figure out what changes were made in the two submited neogeo.c files? It's MUCH easier patching with diff files, since there is actually a program that applies diff file patches automatically, and it will fail (and more importantily it will tell you automatically) when two patches modify the same piece of code in a file. then again this is a windows development environment maybe they don't know "diff -c" and "patch -p1".
For both the submissions I made for 0.58 (Jail Break and Marvel vs. Capcom), I just sent the affected source files, with comments at the bits changed. Not that either where exactly big changes or anything, but still.
