PP - superchsp
Re: PP - superchsp
Once more, stop this comedy. Its boring.
Of course I checked it, 3 times after I saw this thread.
So, you and the other troll insist that you can't play the inp?!...
Ok, what Mahlemiut says?
Re: PP - superchsp
... but did you actually download the file from marp and confirm that you're using that file for your playback, or did you just use a local copy of what you think you actually uploaded. Because clearly two people who have downloaded the file resident on Marp do not get the file you think is there.
Re: PP - superchsp
It's not comedy, it's tragedy that you keep insisting we're wrong when the screenshots of the contents of the uploaded file show that it is not the same file as the one you're trying to playback.PP. wrote:Once more, stop this comedy. Its boring
Re: PP - superchsp
BeeJay wrote:... but did you actually download the file from marp and confirm that you're using that file for your playback, or did you just use a local copy of what you think you actually uploaded. Because clearly two people who have downloaded the file resident on Marp do not get the file you think is there.
I downloaded the file as you did it, too.
Clearly two people are lying.
Yes you' re tragic, wait for Mahlemiut to confirm me.BeeJay wrote: It's not comedy, it's tragedy that you keep insisting we're wrong when the screenshots of the contents of the uploaded file show that it is not the same file as the one you're trying to playback.
Re: PP - superchsp
Currently active superchsp INP seems fine, although it's not the one that Kale linked to.
Re: PP - superchsp
Clearly you didn't download the file linked in the OP and you have since replaced that with a new upload that contains the "correct" inp. So, two people are in fact not lying and you are trying to use the fact that you replaced your incorrect upload with a correct file as a way to try to discredit said people and to try to cover off the mistake that you clearly made because you can never, ever admit when you are wrong.PP. wrote:I downloaded the file as you did it, too.
Re: PP - superchsp
Clearly I downloaded the right file, while you downloaded a wrong file. Mahlemiut confirmed that I was right. Will you now apologize, you poor troll?...BeeJay wrote: Clearly you didn't download the file linked in the OP and you have since replaced that with a new upload that contains the "correct" inp. So, two people are in fact not lying and you are trying to use the fact that you replaced your incorrect upload with a correct file as a way to try to discredit said people and to try to cover off the mistake that you clearly made because you can never, ever admit when you are wrong.
PS. Any editor will tell you that I did not replace anything
Re: PP - superchsp
Nope. You downloaded a different file to the one linked in the OP or you would have seen the same thing as we saw. Try clicking the link in the OP and see what you get. It's not what is currently available under that game name on Marp, so it has definitely been replaced.PP. wrote:Clearly I downloaded the right file, while you downloaded a wrong file. Mahlemiut confirmed that I was right. Will you now apologize, you poor troll?...
Re: PP - superchsp
Once again, cut the comedy. Any editor/mod will confirm that I did not replace anything.BeeJay wrote: Nope. You downloaded a different file to the one linked in the OP or you would have seen the same thing as we saw. Try clicking the link in the OP and see what you get. It's not what is currently available under that game name on Marp, so it has definitely been replaced.
Re: PP - superchsp
Just click the link that was in the original posting and you'll get the wrong file!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!PP. wrote:Once agaoin, cut the comedy. Any editor/mod will confirm that I did not replace anything.BeeJay wrote:Nope. You downloaded a different file to the one linked in the OP or you would have seen the same thing as we saw. Try clicking the link in the OP and see what you get. It's not what is currently available under that game name on Marp, so it has definitely been replaced.PP. wrote:Clearly I downloaded the right file, while you downloaded a wrong file. Mahlemiut confirmed that I was right. Will you now apologize, you poor troll?...
How much more simple can it be to understand that the link provided in the OP shows that the inp uploaded at that time was not for the game in question. Just try downloading that file and all will be clear to anyone with a modicum of intelligence.
Re: PP - superchsp
As I said, I checked inp 3 times after I saw this thread. Nothing was wrong and nothing was changed, and editor confirmed. Why you insist? There is nothing more to discuss.BeeJay wrote: Just click the link that was in the original posting and you'll get the wrong file!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: PP - superchsp
Then you can't possibly be checking the INP linked in the OP. Try clicking that link, not doing a search on Marp or using a local copy of what you think you uploaded, and you'll get the file that was wrong like me and Kale did. End of story.PP. wrote:As I said, I checked inp 3 times after I saw this thread. Nothing was wrong and nothing was changed, and editor confirmed. Why you insist? There is nothing more to discuss.
Re: PP - superchsp
Once more: I didn't use a local copy, I used the marp's one as anybody can, too. You and your friend downloaded a wrong file.BeeJay wrote: Then you can't possibly be checking the INP linked in the OP. Try clicking that link, not doing a search on Marp or using a local copy of what you think you uploaded, and you'll get the file that was wrong like me and Kale did. End of story.
Re: PP - superchsp
How much more obvious do I have to be. It's your frickin file that you uploaded. It's not accessible directly on Marp any more, but if you click the bloody link in the first post you'll see the bloody file that has the wrong inp. But no, you're such a shit you want to keep telling us we're wrong when we clearly aren't but you'll never bloody accept your mistake. Say whatever you want back as a response, I don't give a bloody shit about this anymore or you for bloody sake!!!!!!!!!!!!!!!!PP. wrote:Once more: I didn't use a local copy, I used the marp's one as anybody can, too. You and your friend downloaded a wrong file.
Re: PP - superchsp
ok ok... I just checked file for 4th time. It playbacks like a charm.
Will you now stop the lies and apologize?
