[K10] Round 3 - Ghostlop [ghostlop]
Re: [K10] Round 3 - Ghostlop [ghostlop]
If Gray appears, it turns your game into an 8 stage game instead of a 7 stage game. This gives you more scoring opportunity.
oh sorry i though it was the grey ghosts lol
Inp don't works?
BDFil, I'm having issues with one of your inps again. On the 2nd stage, the game freaks out and goes into the service mode menu - the same exact thing that happened in Cosmo Gang. I'm not sure *HOW* this is happening, but...
Using default bios?
Made sure there are no files in the memcard subdirectory?
Haven't had a problem watching anyone else's inps so far.
Deleted NVRAM?RdP wrote:Inp don't works?
Using default bios?
That is a big problem, because i controlled everything before attacking hangon.
I also watched full inp before sending it to you and that one was working perfectly on the computer i played.
I have a new inp so i am actually watching it on another computer.
No idea where it comes from?!
Jerome
I watched my full inp (74882) on another computer and it works fine.
I do not know what to do?!
Jerome
screen is off centre in 106, and does not work in 148. "required files are missing".
thats me out.
good luck all!!!
thats me out.
good luck all!!!
Blah managed 60k. Will just have to wait and see if thats enough to get through!
Andrew Barrow
I was referring to your previous inp of 64497...BDF wrote:I watched my full inp (74882) on another computer and it works fine.
The new one plays back just fine.
You have to disable "stretch using hardware".kernzy wrote:screen is off centre in 106, and does not work in 148. "required files are missing".
thats me out.
I also watched my 64497 inp on the computer i used to record it and it worked perfectly.BBH wrote:I was referring to your previous inp of 64497...BDF wrote:I watched my full inp (74882) on another computer and it works fine.
That is the reason why i tried my new one on another computer before sending it to you.
Jerome
Update your Neo Geo BIOS (neogeo.zip).kernzy wrote:screen is off centre in 106, and does not work in 148. "required files are missing".
thats me out.
good luck all!!!
Only the ghostlop ROM filenames have changed, so if your ROMs are zipped, then there is nothing to do.
As for the off-centre screen, is it the same when running in a window, as it is fullscreen?
hey Barry!
thanks for your help.
unfortunately, it had no effect. well, it has, now ghostlop has vanished from my list! why does it do that? happens often nowadays, when i audit all games, some go missing.
i tried street fighter, and that is still off centre.
ok, just tried running in a window and that seems to work fine.! wahey!
so i'm still in the same place. in fact, worse!! lol!
i doubt if i will compete anyway. puzzle bobble has never been on my screen, and i sucked at the other games. maybe i will not even qualify, which is embarrassing!
BBH has done me over!!!
oh, well, maybe next year.
cheers guys, and good luck!!
The current Neo Geo BIOS works fine in both 0.148 and 0.106. You will get warnings in 0.106, but it will run.
You can ignore these, they have no effect on playbackability. Set your frontend to view all games, not just the available ones, that should stop it from "disappearing".
sm1.sm1 WRONG CHECKSUMS:
EXPECTED: CRC(97cf998b) SHA1(977387a7c76ef9b21d0b01fa69830e949a9a9626)
FOUND: CRC(94416d67) SHA1(42f9d7ddd6c0931fd64226a60dc73602b2819dcf)
000-lo.lo WRONG LENGTH (expected: 00010000 found: 00020000)
000-lo.lo WRONG CHECKSUMS:
EXPECTED: CRC(e09e253c) SHA1(2b1c719531dac9bb503f22644e6e4236b91e7cfc)
FOUND: CRC(5a86cff2) SHA1(5992277debadeb64d1c1c64b0a92d9293eaf7e4a)- Barry Rodewald
