Page 2 of 2
Re: *jrpacman-fast
Posted: Mon Feb 22, 2010 3:13 am
by negative1
a few other things.. if you want to watch the 'slow' - normal
version high score replay..
(mame 35b13 version)
in order to get this working.. you need to 'fix' the roms..
rename jrprom.5s to pacman.spr (i think this is the sound?)
rename jrprom.9e, 9f, 9p
to -> jrpacman.9e, 9f, 9p
you'll get some error messages.. but ignore them..
it'll run fine, the sound will be off (scratchy).. but it works fine..
i'm using the latest version of DOSBOX to run mame in a window under
vista... it works fine since it emulates sound blaster card, and video..
good for learning techniques..
later
-1
Re: *jrpacman-fast
Posted: Mon Feb 22, 2010 8:02 am
by Weehawk
negative1 wrote:i'm using the latest version of DOSBOX to run mame in a window under
You may be the first person I've heard report a means to run old DOS-based MAME versions on a Vista or XP machine.
Might be worth posting separately in the General forum about this program.
I still keep a Windows 95 machine tucked away in a closet in case I ever absolutely must see an old recording.
Re: *jrpacman-fast
Posted: Mon Feb 22, 2010 10:27 am
by negative1
Weehawk wrote:negative1 wrote:i'm using the latest version of DOSBOX to run mame in a window under
ouch.. yeah, i have some old computers around with old os'es..
but i put up a pointer topic under general:
viewtopic.php?f=2&t=14631
hope it helps..
let me know if something doesn't work...
later
-1
Re: *jrpacman-fast
Posted: Mon Feb 22, 2010 10:58 am
by dbh
I installed Windows 98 into a VirtualPC for this purpose, although I do still have an actual machine with it too just in case. I should make a Windows 95 one, too.
Re: *jrpacman-fast
Posted: Mon Feb 22, 2010 12:32 pm
by negative1
dbh wrote:I still keep a Windows 95 machine tucked away in a closet in case I ever absolutely must see an old recording.
that was the first thing i tried..
but maybe (since i had the free version).. it would not let me
point to my physical drives, so i had no way to access
the directories/games/roms that i had set up..
oh, and thanx for all the great replays don!! i just watched the 1.7million in centipede!!! (sped up at parts)..
i wish i could use savestates, and practice the upper levels.. you seem to be on a tear the last couple of
years with some unbelievable high scores!! i haven't touched any games in about 8 years or so..but i have
the bug again..
you should check out the centipede/millipede clones.there's a lot more out there that could use high scores,
mine aren't that great anymore...i'm getting used to a trackball now..no more mouse.. or maybe my
reflexes aren't that great anymore...
later
-1
Re: *jrpacman-fast
Posted: Tue Feb 23, 2010 11:12 am
by dbh
I'm not sure if VirtualPC lets you directly access the physical drives. The way I have it set up, I copy only the MAME pieces I need into the VirtualPC environment. It would be nice if it could access the machine's physical drive, though!
the bug again..
Thanks
Yea, I should...just need to find the time to get around to it
Re: *jrpacman-fast
Posted: Tue Feb 23, 2010 4:59 pm
dbh wrote:I'm not sure if VirtualPC lets you directly access the physical drives. The way I have it set up, I copy only the MAME pieces I need into the VirtualPC environment. It would be nice if it could access the machine's physical drive, though!
Not sure if it can be done directly, but in VMWare and VirtualBox, you can set up network shares to access files on the host or another networked system. I've never used VirtualPC, but I'd figure that it'd have the same feature.
Re: *jrpacman-fast
Posted: Fri Mar 05, 2010 9:31 pm
by CrazyKongFan
I wonder why a true turbo Jr Pac hasn't been added to MAME yet? There's definitely a ROM out there for it, I know of at least 4 machines that have it. If it's a 2700 series EPROM, I might be able to dump one from a friend of mine's board.
