Sawys' Scramble Spirits recording
Time
Missions completed in 35 minutes from the beginning till the game over.
But if this is bad for me, my problem is that i have no way to know if i am under the real speed with Wolfmame.
Maybe there is a bug with the configuration in my system.
Ok, that game should have only taken 15 minutes by my calculations. There's something mightily strange going on if 100% speed is reported, when it so obviously isn't running at 100%.
Are there any unusual programs that you have running in the background that may cause this... antivirus programs can sometimes cause problems.
First : I have no antivirus, only msn messenger closed, image transfer and In Cd. I don't know what happens.
Second : I post this score on my 2nd game. I discover this game and know that 2nd place is easier to reach than 1st but I will later play better.
You know I just have a baby on 11th april 2004 and I have no much time to play. I try to make it but it's hard now !
Plus
I wanted to add that as i said when you choose the olympic leader board, now , the most important is the rank and not the score and for me it's not important if I am 2nd or 1st.
If the score to beat is easy in the 2nd place, i make it and later i will be back when someone beats me.
The modification of the leaderboard changed my way of thinking and playing with MARP.
Re: 2 answers
So maybe you have virus thensawys wrote:First : I have no antivirus, only msn messenger closed, image transfer and In Cd. I don't know what happens.
Buttermaker
Screenshot
Here it is
Buttermaker
Re: 2 answers
Funny ; my twins are born 11th april 2003sawys wrote:You know I just have a baby on 11th april 2004 and I have no much time to play. I try to make it but it's hard now !
1 - Here is the screenshot if this is ok.
2 - Phil Lamat, are you french because I saw your highscore in http://www.jvrm.net. You are good to Mahjong !!
Re: 2 answers
Français jusqu'au bout des ongles, oui ;sawys wrote: 2 - Phil Lamat, are you french because I saw your highscore in http://www.jvrm.net. You are good to Mahjong !!
j'ai par contre peu de scores sur Jvrm car je te laisse découvrir la vie avec un enfant, et tu comprendras vite que s'il y en a deux ...
Buttermaker
Re: 2 answers
Not exactly. I said mamep.exe, not mame32p.exe. In your "exécuter" window type cmd and hit return. That is the command prompt. Run mamep.exe from there and take a screenshot of the command prompt window after MAME finishes.sawys wrote:1 - Here is the screenshot if this is ok.
The good screenshot
Here it is again !
